Brake bias valve thingy
When your freeing these up is the spring meant to be loose? Falling from side to side? Or is there meant to be another spring to take up the slack? Thanks
The spring should only be loose when jacked up in my experience.
(30-01-2013, 06:55 AM)puglove Wrote: The spring should only be loose when jacked up in my experience.
It's pretty clear....
When the cars on the ground, the spring should be under load. When jacked up, it shouldn't be. Simples.
Yeah grant!!!!!! What niall said
  rear brake bias replacement zx_volcane 3 3,806 10-10-2016, 04:49 PM
Last Post: welshpug
  Brake pipe routing with manual bias valve Lolben91 15 7,903 26-04-2015, 09:23 AM
Last Post: adam b
  bypass brake load valve blinkyeatu 0 1,794 05-02-2015, 05:51 PM
Last Post: blinkyeatu
