Caliper Brake Line differences?
Do the range of 306 calipers: 247, 266 & 283 share the same connection on the brake lines or do they vary caliper to caliper?
Therefore when getting braided lines done can they be used across the range of calipers or do they need to be specific to the caliper?
Cheers.
90% sure there all the same
Yep all the same.
Can sort you any braided lines you want
  Brake line fittings RetroPug 0 1,824 28-04-2018, 07:39 PM
Last Post: RetroPug
  Brake compensator differences Ben_w 8 7,052 03-03-2018, 01:44 PM
Last Post: Mighty306
  Rear brake caliper overhaul Mighty306 18 12,463 19-02-2018, 10:55 PM
