25-12-2011, 07:38 PM
Ruan Wrote:just make them pass as much air as physically possible.i do this a lot
oh riiight turbos...
t2 turbo
Ruan Wrote:just make them pass as much air as physically possible.i do this a lot ![]() oh riiight turbos...
25-12-2011, 07:44 PM
Ruan Wrote:These engines will produce good torque, not quite like a DI, but they will produce more than enough for our needs, the key with these engines is getting the fuel in past 4000rpm... You can strap on big blowers, but when they only start coming on strong past 3000rpm, you've got 1000rpm to play with... Bosch M pump it is... or advance piston mods for those brave enough... I got the VE figure from using a completely standard XUD9TE thats producing 90 hp and 145 lbft with 14 psi of boost the usual figures....
25-12-2011, 07:47 PM
Also the higher quoted figures, where am I able to get those from? So I can compare the results of my finding to those..... I've always worked from my results to come to my own conclusions but any other data would be good to look at also.
25-12-2011, 09:19 PM
Advance really isn't the problem, no need to play with it, especially on a 9mm, but on an 11mm, it's so to cock it needs playing with...
I've seen figures of 85-87% for ALH TDis (8v VP pumped early TDis) - I know for a fact that our XUD heads flow as well or better than the TDis, they're IDI, you need no swirling - that's why you have PCCs, the valves and ports in the XUDs are massive in comparison...
25-12-2011, 09:40 PM
And the fact the cylinder bores are about 4 mm bigger would also dictate that also.
25-12-2011, 09:56 PM
Jarrus Wrote:Pretty much sums it up, also those flow rating are according to the manufacture, you can make more or less on that but that's kind of a kind line figure, Nah it's kl, don't take it as being patronising, i understand that and it's good to have it all layed out even if it's the quite basic fundamentals. Most of my time is spent this semester delving into neuroscience shizzle so i have bugger all time to spend on cars which is shit and i loose track of the things i've picked up. They're the only thing that keep me sane! Haha This is good stuff!
![]() Dturbo GT2259s build thread; http://306oc.co.uk/forum/thread-3692.html Daily driver; 330d Msport (doesn't blow up!)
25-12-2011, 09:58 PM
Ruan Wrote:These engines will produce good torque, not quite like a DI, but they will produce more than enough for our needs, the key with these engines is getting the fuel in past 4000rpm... You can strap on big blowers, but when they only start coming on strong past 3000rpm, you've got 1000rpm to play with... Mmmh, well my veg oil ethos is going to help matters for me
![]() Dturbo GT2259s build thread; http://306oc.co.uk/forum/thread-3692.html Daily driver; 330d Msport (doesn't blow up!) |
