08-12-2011, 07:41 PM
what boost have people run on them? should i go from gt15 to a t2? , i want too but the lag is putting me right off :/ when does the t2 turbo come on full boost ? cheers
t2 turbo
08-12-2011, 07:44 PM
Should be on full boost just after 2k. Theyre really not that laggy at all, just more laggy than a GT15. Imo go for the swap, my friend has just done the exact same. As for boost, upto around 23/24 seems reliable, they will boost upto ~32 though, although dont expect them to last more than about 6 months if you run them that high and drive them hard.
08-12-2011, 07:51 PM
2kyou sure? there somthing wrong with my gt15 then as it at full boost 1,900 minium that with an exhaust with hardly any restriction at all, you have convienced me
08-12-2011, 07:55 PM
I think the amount of time it takes to hit full boost will depends entirely on what PSI your looking for, a T2 would not hit 20 psi by 2k
08-12-2011, 07:58 PM
im running 21psi how long would it take the t2 to hit that? i will have a exhaust with little retrsiction any idea what it would hit that at?
08-12-2011, 07:59 PM
Mine hits peek boost (24 psi) at ~ 2.5krpm and holds it all the way up to 5.5k!
Cracking stock turbo.
08-12-2011, 08:01 PM
Didnt have a rev counter in my 205, but by using the gear ratios and mph I worked out my K14 could hit 17psi at something like 19xx rpm. Smaller displacement though, and no IC whatsoever, so may have dropped lag a little.
08-12-2011, 08:12 PM
about 600 revs more :/ hmm im sure if i put it on that 600 will seem like nothing once its on boost. i need to man up i think
08-12-2011, 08:26 PM
Mate a T2 is not laggy lol, get it on and man up.
Peugeot 206 GTI HDI
Volvo V50 2.0d Volvo XC90 D5
08-12-2011, 08:54 PM
i suppose it laggy standard as your not getting the most out the turbo but running 20psi plus it comes into its own think i will fit it.
09-12-2011, 01:01 AM
Try running a bigger blower, T25 dosent even start boosting untill like 2.5k and peaks around 3k
09-12-2011, 12:42 PM
uk u have put me right of a t25 that is way to laggy :/ think after my t2 i will just have to get a hybrid turbo or any gt model.
09-12-2011, 12:43 PM
liam doidge Wrote:uk u have put me right of a t25 that is way to laggy :/ think after my t2 i will just have to get a hybrid turbo or any gt model. Marks T25 isnt that laggy, seemed fine to me 306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam
09-12-2011, 01:25 PM
Yeah its weird it dosent feel too laggy its nowhere near as bad as you think..
09-12-2011, 01:27 PM
T25 are not laggy, yes more than a t2 but only just.
09-12-2011, 01:35 PM
go for a GT15, t2's are for teh no00bz!
09-12-2011, 01:38 PM
Coming from the guy who is picking the wrong turbo for his car lol.
Me and connor, tried to change your mind yet still you are going after the wrong turbo. If you dont want to fit a different turbo from another car the T2 is th best standard turbo. I took JP out in my car and he said mine felt better than the tdo4 car he went in.
09-12-2011, 01:47 PM
Pompey306mark Wrote:Coming from the guy who is picking the wrong turbo for his car lol. but my car is going for as much low end as possible, i dont want the "POWWAHAHHHH BHPPP!"
You still want a t2. As you will only moan when the ting gt15 blows up.
09-12-2011, 01:54 PM
i want low end but i dont want to be picking up the remains of my gt15.
09-12-2011, 01:57 PM
T2 it is then, simples.
09-12-2011, 02:09 PM
*facepalm*@ginge
09-12-2011, 02:18 PM
If you want more driveability then a GT15/KO3 would be better, if you want more high up power then a T2/K14 would be better..
09-12-2011, 02:20 PM
T2 does not give higher power. My t2 gave great driveabilitly. T25 and above gives high up power. The T2 if a great turbo.
Listen to the people who have done it. I had KK14 and T2. T2 was better, gave great driveability but I was pushing it at 25+ psi. This is why I moved up to T25 as they can flow more air and should last longer. My T25 comes on strong at 3,000 but starts to build before that. If you can keep the power in the corners then the T25 does not need to come out of its power band. I drive my car very day and have not issues with the T25 on my car.
09-12-2011, 02:25 PM
Its great for a standard engine with just a stage 1, but after that, you need to be looking at uprating the turbo imo
09-12-2011, 02:45 PM
I've had a k03, that was well....boring, and imo pretty shit for ultimate power. It's like what the other guys have said really..depends what your looking for.
The t2, is like the best of both worlds imo...pretty quick spool up, and not too bad up top end...but obviously know where near what a big mofo turbo could do! ;D
PH1 306 XUD - 11mm VE, Big 'bine, TMIC = Plenty of coal, abuse, heatsoak and a power band of 4.3k - 6k = One shagged car.
09-12-2011, 02:54 PM
My T2 had enough power to keep up with fooby in his 6 last year. But I was deffiniately pushing it beyond its limit.
Go T2 and when you get bored go T25.
09-12-2011, 06:37 PM
i want no lag but power like a t25, i am in dream land and i know it but i still want it lol.
