VAGAGAY K04- it's boosting!
#91
The drill arrived and I've managed to get 5 out of 6 holes counter sunk, but the 10mm drills gotten blunt
Stage 2 XUD Sedan
#92
bust the file out and sharpen it up again
#93
does anyone know what cars came with a gt2052 on?
#94
GT2052S or GT2052V?
S - LandRover TD5, Rover 75 1.8T few others I can't remember off the top of my head...
V - Volvo D5, Audi 2.5 V6 TDi, BMW 525D, few others too...
#95
d-jimbo Wrote:does anyone know what cars came with a gt2052 on?
Abit off topic.. whistle
Stage 2 XUD Sedan
#96
Yeah, I know. Sorry about that. Gt2052s.
#97
Right then, well over due an update so here's some pics of it mounted to my spare engine. Bear in mind it's not finished yet as I was just trying to find the best postion so it clears everything.
[Image: IMAG0854.jpg]
[Image: IMAG0856.jpg]
[Image: IMAG0860.jpg]
[Image: IMAG0862.jpg]
Stage 2 XUD Sedan
#98
Due to a slight error the angle of the turbo will have to sit leaning to the right slightly, does this mean it wont mount on to the exhaust?
P.S does anyone know how to change the title of this thread as it's not a hybrid thread anymore..
Stage 2 XUD Sedan
#99
Could make the exhaust a farse fella, probs have to cut the downpipe / spin it a bit and weld it up to get away with it, might be able to spin on the joint and run whole downpipe and funny angle, but probs foul linkages etc....id try and straighten it up a bit if I was you...
[Image: sigi-2.png]
It's the shape of the plate which has caused it so it match's up with holes. The other option would be to make new holes and tap a thread in the fanimold but i'm worried about it weakening it causing it to crack. It will hopefully only need 1 extra hole.
Stage 2 XUD Sedan
strictly_derv Wrote:Due to a slight error the angle of the turbo will have to sit leaning to the right slightly, does this mean it wont mount on to the exhaust?
As Darren has said, it will make fitting the exhaust a bit of a nightmare Sad I noticed that it was on an angle but was at work and for whatever reason didn't reply to your thread!
To change the thread title if you go to the first post and click "Edit" at the bottom you should be able to change the title and that will change the thread title Smile
Team Orange Engine Bay
Cheers Mark. I have got the turbo to manifold holes drilled yet, if you look closely you can see the molegrips holding it in place
Stage 2 XUD Sedan
[Image: IMAG0879.jpg]
ninja
Stage 2 XUD Sedan
Winnar!!!
IMHO you should just remove the stock Peugeot downpipe, weld on a 90* mandrel and then just get a sleeve section and clamp that on... Essentially what I did with the VNT...
Overkilled but will do the job nicely lol
Ruan Wrote:Winnar!!!
Have you got a picture you can link/send?
Dan I don't want it blowing open lol
Stage 2 XUD Sedan
[Image: 100_2143.jpg]
[Image: 100_2145.jpg]
[Image: 100_2146.jpg]
[Image: 100_2147.jpg]
[Image: 100_2148.jpg]
[Image: 100_2149.jpg]
Stage 2 XUD Sedan
Yaaay looks awesome !!!!
On the 306 waiting list.
are you going to be able to get the exhaust downpipe spring loaded bolts on there?
Doubtfull, nothing a grinder and welder can't fix though, that's how mine was fitted.
The picture looks worse than it is...goes to check....might need a slight grind lmao
Cheers for pointing that out, it didn't occur at the time.
Hopefully I'll be fitting it friday. I've got a rolling road session booked in for saturday so I might have to cancel it and do another when it's set-up properly.
Stage 2 XUD Sedan
Looking good, cant wait to see the results!
Oooo turbo porn! Good work fella! What are you hoping for on the dyno, 180ish?
HDi Cabby Project Click
That 205 is going to be an animal!
Don't know what to expect TBH. Anything over 155 and i'd be happy. Even if I get 170bhp it will be nearly 200BHP per tonne which is only a few do2wn from the new Focus RS Confusedhock:
This weathers looking pretty shit for a turbo change Sad
Stage 2 XUD Sedan
dont leave the nylock nuts on, as the turbo warms them up they will loosen as the plastic softens-------motor factors usually keep boxes of brass locking nuts; they are mis-shaped so they bite onto thread as it passes through them.
Thanks for that daddfixit.
I've been attacking it with an angle grinder after work as I realised a few bit where'nt seating right. Glad I spotted that as it wouldn't of been fun finding it leaking on the car! Also ground away that spacer near the down pipe bolt hole so it fits in easily.
Just praying on the weather now :pray:
Stage 2 XUD Sedan
The turbo's is on! :dance:
Stage 2 XUD Sedan
Winnar!!!!! Where's the chronic boost videos!!!! Big Grin
A few teething issues but but she's goes, considering it's a full turn out on the fuel screw, exhaust pipe not connected properly and a boost leak, it does go.
Stage 2 XUD Sedan
  Lucas K14 Boosting 2 Bar daveylennon93 9 6,767 01-01-2015, 01:42 PM
Last Post: daveylennon93
  top mount td04 not boosting DagDag53 24 13,205 04-12-2014, 09:24 PM
Last Post: daniel.mountain.7
  XUD *over boosting* ? ADV_93 6 5,426 01-08-2014, 08:21 AM
Last Post: Ruan
Users browsing this thread: 13 Guest(s)
