XUD *over boosting* ?
Hello everyone, basically the question i'm asking is... Can you make a d turbo create more boost than is needed for the fuelling? I'm running a Lucas and a K14 (at 18 psi) atm and i'm still creating a lot of smoke on boost. I know why etc. However, with my MBC, if i was to wind it to the fully "+" position, will it be boosting 38 psi or whatever or will the fuelling limit the boost created? I'm not too clued up on how the fuelling can control boosting, so if someone could explain it would really help, thanks Smile
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
i don't think you can, believe you need fuel to create boost . .Smile
Reduce fuel or increase boost.
A k14 wont do 38psi....not with your setup!
(31-07-2014, 09:04 AM)Mattcheese31 Wrote: i don't think you can, believe you need fuel to create boost . .Smile
So the boost will only go to what the fuelling can create?
(31-07-2014, 09:28 AM)Piggy Wrote: Reduce fuel or increase boost.
As long as the engine can take it! Not 38 psi lmao, just a random figure!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
(31-07-2014, 09:34 AM)ADV_93 Wrote: So the boost will only go to what the fuelling can create?
Exactly, less fuel = less exhaust gas being produced = less pressure the turbo makes
Unless you bolt on a VNT and have 30psi at idle Wink
It's only because the stock turbos are crap that you can do this...
Most modern units will move so much air with so little exhaust gas it's unreal.
  Lucas K14 Boosting 2 Bar daveylennon93 9 6,961 01-01-2015, 01:42 PM
Last Post: daveylennon93
  top mount td04 not boosting DagDag53 24 13,760 04-12-2014, 09:24 PM
Last Post: daniel.mountain.7
  Over boosting ??? Dan306DT 25 19,240 01-10-2013, 06:32 PM
Last Post: scottbmxer
