XSI Twin Turbo
XSI Twin Turbo
#61
oh, no idea, fit the standard pulley then, as you don't need an adjustable one.
So, while im waiting for my cylinder head to come back from machining, my focus has recently turned to suspension.
I want to widen the track but I dont want spacers, I just dont like the idea of them.
I do want rose jointed, tubular wishbones though. So I was thinking if I were to make some wishbones up that were say 40/50mm longer, move the top mount 40/50mm and make/source longer driveshafts and track rods that were 40/50mm longer as well.
Then as long as everything is sized up exactly the same then geometry shouldnt change??
I realise its a lot of cutting, welding and fabrication etc, but im not too fussed about that
The front camber will change significantly if you do that, cba to do the calculation, but it'll be a lot.
(01-01-2018, 02:52 PM)Poodle Wrote: The front camber will change significantly if you do that, cba to do the calculation, but it'll be a lot.
wont change whatsoever if bottom and top are moved the same distance
I totally missed the bit where he said he'd move the top mount, I'll stfu lol.
This project isn't dead yet!!
Everything's been on hold the past couple of months due to weather, other cars breaking down etc and will be on hold for another few weeks. Mainly because I've managed to convince my land lady to get me a nice big double garage with power/lighting!! So I'm waiting until that's up before doing any more work on this.
I did pick up my cylinder head a couple of weeks ago though and now I have everything bar head gasket and head studs to rebuild the engine.
Have also been looking into a sadev gearbox, but that's mega money! And the hassle of getting driveshafts made etc. I may just have to blow a few standard gearboxes for the time being lol
What have to decided on in the end then? Still the two T28 turbos running together?
(23-04-2018, 01:26 PM)JTaylor2005 Wrote: What have to decided on in the end then? Still the two T28 turbos running together?
Yep! If it doesnt work then I can, in theory, just blank the second turbo off and run it as a normal single setup. But if it works... it should be fun!!
Been getting a little bit carried away with ideas this evening... Sadev do a 4WD box for transverse engines! All I need to do now is win the lottery...
The new mancave is up!
So, gonna pull the XUD in, give that a full engine rebuild. Then once thats out the way in goes the XSI, and the real work can commence!  Rofl
(27-04-2018, 10:38 PM)PugLee Wrote: Been getting a little bit carried away with ideas this evening... Sadev do a 4WD box for transverse engines! All I need to do now is win the lottery...
would the old Fiat Panda 4x4 box work?
Hate Housework!
Not sure, been looking at evo boxes and having an adapter plate made. I'm more worried about a rear setup, it's a lot of fabrication...
simplest setup would be live axle/leaf-spring.
http://www.awdwiki.com/en/fiat/#Panda_I_4x4__1983_2003_
Hate Housework!
also the most terrible and pointless.
(07-06-2018, 08:09 AM)welshpug Wrote: also the most terrible and pointless.
which? the Panda box? would that not depend on the amount of abuse it was destined for?
Hate Housework!
wow. what a mancave that is!
(Jealous)
Hate Housework!
I think he means the live axle setup, whilst is it the simplest, performance wise it offers very little!
(12-06-2018, 10:32 PM)PugLee Wrote: I think he means the live axle setup, whilst is it the simplest, performance wise it offers very little!
which was my point in some parts, ie, the fabrication thereof.
Hate Housework!
Ok so I've decided to go for 4WD, currently sourcing parts for this so watch this space!
As for suspension, are there any geometry wizards on here who want to help me design a double wishbone setup all round?!  lmao
I think I may have to practice my welding lol
Nothing on the car front im afraid, just a little update on the garage.
Ive had this week off work so I got the walls painted. The sparkies have been and worked their magic, apart from their supplier gave them the wrong size junction box to wire it all up to the house! So they're back on monday to finish up and get it all switched on.
Also built my workbench, went al little OCD and the carpenter in me came out!
Gonna spend some money and kit it out a little after payday, air compressor, grit blaster, parts washer, new welder etc. Also got some heavy duty floor paint to do the floor and the workbench. Hopefully I can actually get on with the cars then!!
oh man. Jealous much!
So I spent a bit of money this month...
Nearly setup properly now, XUD is still being worked on for now so not long until the project is rolled in
On a side note, how do I get these out without breaking them?’
Gently prise the middle bit upwards with a flat blade screwdriver. That pulls out then the plug part it sits in will come out. The pin in the middle pushes the mounting tabs on the plug outwards (you'll see what I mean when it's out)
Only one of them came out without breaking!
not exactly double wishbone all round but a scrapped Sierra 4x4 may be a good base for the oily bits.
Hate Housework!
Lee - that man cave is starting to look awesome already - everything you need in one place for resto work, love it!!
190k Moonstone 3dr HDI sold
(02-10-2018, 08:51 AM)Magenta Sunset Wrote: not exactly double wishbone all round but a scrapped Sierra 4x4 may be a good base for the oily bits.
A scrapped sierra 4x4 is worth more than a roadworthy 306  Rofl
62k Diablo Phase 1 Gti-6:
Project Thread
So is a half eaten packet of wotsits tbf...
Its not about the money, but the love of the car!  Rofl
Thumbs Up (SHOW TIME )project number 3 twin turbo ( SHOW TIME ) pioneer DJ paddy 77 33,206 28-07-2017, 08:53 PM
Last Post: pioneer DJ paddy
Video project number 2 twin turbo :-) how she looks now (-: pioneer DJ paddy 138 62,464 03-03-2016, 04:31 PM
  Daves Compound Twin turbo XUD Dave 333 150,584 11-09-2015, 10:30 PM
Last Post: Dave
