heater matrix flush
heater matrix flush
Guys,
if you've seen my resto thread, you'll know things dont look great from a matrix point of view....
going to try flushing it first. Planning on doing so with a gentle flow of water backwards through the matrix. Question is, which of the matrix pipe attachments do I need to feed the water into. The one nearest the drivers side or passenger side?
[Image: IMG_20160417_144933_zpsd4erkgq0.jpg]
[Image: WP_20160730_12_41_10_Pro_zps7cjcoaps.jpg]
I'm guessing it doesn't matter dude, although if you want to back flush I think you need to go up the right one Smile
Cheers Matt,
confirms what I was thinking
Ben, if you reattach the pipes, then you can connect a hose pipe straight in to the pipe, flush at a higher pressure and flow rate thus getting more shit out.
Also with this method you can see if the matrix is leaking still.
  heater matrix swap jayspug86 32 16,803 06-01-2015, 06:06 PM
Last Post: jayspug86
  Heater matrix DeeTurbo 10 5,707 06-06-2014, 08:09 AM
Last Post: londondan86
  Changing heater matrix... Matt-Rallye 7 4,212 05-02-2014, 10:40 AM
Last Post: Mikey
