Threads: 465
114
Car Model/Spec: Vauxhall
£10 for 5ltr can cheap i fill a spray bottle and use it on everything from oil spills to tar spots on the car
Storage is an issue for bulk buying though. I have to buy fluids on a 'just in time' basis atm lol. Could've had some really cheap quick detailer from a valetter mate that makes it if I could buy a huge bottle but just can't store it.
One day I'll have a garage hopefully lol, pita trying to store everything in a wardrobe.
Threads: 213
Car Model/Spec: HDI
Store it under the kitchen sink Tom... You have no Mrs telling you what you can and cant do
Under the kitchen sink is already full of detailing stuff, bucket, hose, etc.
Threads: 101
Car Model/Spec: 306HDi 90 LX
Tom, I rent a garage off my local butcher.
It goes, it stops (as reqd).
Hate Housework!
(25-05-2016, 10:42 AM)Magenta Sunset Wrote: Tom, I rent a garage off my local butcher.
Well that's his cover story for the blood splashed on the walls anyway...
Just want to check if there is any interest in the '6 on here before I spend money putting it on ebay? Don't want to waste half an hour making an ad here when theres already one on gumtree lol.
Threads: 102
9
(20-05-2016, 11:12 PM)Toms306 Wrote: So took this to the retro meet with rowells Rallye tonight and amazingly didn't break down...
Well, except the window wouldn't close when I got there lol...seems to have just been a door loom plug though.
Update on the heater issue... if I set off with the dial on cold, sometimes it will stay cold for the entire trip, if I move to hot then back to cold it stays hot though! . I'm out of ideas there, the panel still doesn't illuminate but the ac and recirc buttons do, and the fan speed control works so it's obv getting power.
Also got some bolt extractors for 2 quid off eBay so may charge up the drill and try to get one of those stuck in the rear arb bolt this weekend. And see if I've got a washer to put on the strut top nut which is knocking like mad.
I still don't have the v5 yet.
it could be the wiring/ connection on the dial for the heater system acting up. Not sure how dial system is setup on the 306. But on the rover it uses wire system switch from hot and cold, and to change vents from the window screen.
it might need cleaning down that's all tom, and spraying with WD40.
Be something daft mind like that, the fun part would be stripping and access!
Threads: 162
21
Just a quick check, have you checked the thermistor in the map reading light bit is ok, plugged in and not covered in shit?
Sent from my Nexus 4 using Tapatalk
It's definitely plugged in, I didn't check if it was covered in shit tbf though.
So the squeaky blower drove me nuts, relay removed, problem solved.
In other news I now have the V5 (only takes 2 days with the online thing!) so this is properly for sale now.
Car is being SORN'd now the month is over. £1200 takes it, no offers.
It's gone to it's new home tonight.
Threads: 371
29
Car Model/Spec: ford fiesta
did you tell them if the bolt comes loose on the speedo housing to hammer it back in
Threads: 162
21
Is it a forum member?
31-05-2016, 07:33 PM
(This post was last modified: 31-05-2016, 07:37 PM by Toms306.)
It won't come loose. You only hammer past the first few threads then it tightens normally. I thought you were a mechanic!
(31-05-2016, 07:33 PM)DeeTurbo Wrote: Is it a forum member?
Not sure. He's a well known Peugeot guy and has been to a few 306 meets but not sure if he's actually on here!
His weekend toy is a stripped 205 GTi with a 2.2 bottom end, GTi6 head, performance cams and throttle bodies...
81
How much did it sell for tom?
Threads: 213
Car Model/Spec: HDI
Looking forward to seeing the newest addition Tom
(31-05-2016, 08:10 PM)Eeyore Wrote: How much did it sell for tom?
You already know I swapped it for a feminine hygiene product.
(31-05-2016, 08:31 PM)Piggy Wrote: Fiesta ST?
Maybe...
Ooohhh. Ford fanatic now.
Easy to mod those! Love the chassis...do need more umph...but easy enough. Inlet change, downpipe and exhaust change and a remap sees them to 170ish bhp.
Also 300mm brake calipers from the mondeo direct fit...
I used to dabble with fords ;-)
Haha, I'm still firmly a VAG fan really, but do like a decent Ford!
I was offered this as a swap and seemed like a decent deal so went for it, don't think I'd have chosen one otherwise though! But I must admit, from a brief run round I was pleasantly surprised by the power from it. Only 150bhp but I guess the lightness makes up for it, not sure, but it certainly doesn't feel 'slow' anyway. Brakes don't feel all that great though, seems to be a Ford thing to put on brakes that are too small for the job lol.
It already has a Miltek catback. And I was given the Miltek decat but I probably won't use that as I like staying legal and MOT friendly. I did wonder if it's been mapped but the previous owner never said anything so I would assume not.
I haven't really got much budget at all for this though, the idea was to sell the '6 and get something ~£200 cheaper so I had £200 to spend on it. Not to straight swap with a car that I reckon is worth nearly twice as much but it's funny how things work out lol. So probably won't be modding it further any time soon, unless things up cheaply anyway lol!
I will of course post pictures in an 'other marques' project thread for it when I've cleaned it up a bit.
Threads: 136
11
Decent and ford in the same sentence?!
Maybe from the 1980's
Yeah the ST is still worth a lot more than a gti6.
The elbow pre cat is the most restrictive part of the exhaust system.
(01-06-2016, 07:12 AM)Paul_13 Wrote: Decent and ford in the same sentence?!
Guess you've not had any modern ones then.  I agree the 90s ones were pretty poor, Mk1 Mondy, Mk1 Focus, Mk4 Fiesta....Eurgh...
But I meant decent as in spec, not shitty Studio's, Styles and Zetecs lol, Ford are so stingy with spec unless you buy one with a big engine, high spec and then add a load of options!
Threads: 18
10
(01-06-2016, 07:44 AM)Toms306 Wrote: I agree the 90s ones were pretty poor, Mk1 Mondy, Mk1 Focus, Mk4 Fiesta....Eurgh...
I disagree - whilst the early 90's stuff was a bit dubious, by the late 90's Ford were producing various class leading cars that drove superbly.
Puma, Mk1 Focus, Mk2 Mondeo and whatever that era Fiesta was (Mk5?).... all handled and drove brilliantly.
It's just a shame that they dropped the ball when it came to rust protection, hence the smaller Fords of that era (especially Ka's) being such a problem rot wise now.
Threads: 52
Car Model/Spec: P3 306 16v XSI
Tom, have you got the pre-facelift or facelift version?
(01-06-2016, 09:15 AM)powerandtorque Wrote: (01-06-2016, 07:44 AM)Toms306 Wrote: I agree the 90s ones were pretty poor, Mk1 Mondy, Mk1 Focus, Mk4 Fiesta....Eurgh...
Each to their own I guess!
Protection is still an issue on them now unfortunately, as well as the sills rusting out before 10 years old they use cheap paint and can't put lacquer on thick enough. The grit/gravel rash on the doors is still awful on the latest Focus and the paint comes off under the sills pretty quick as well still. Mud flaps (like mine has fortunately) do help a bit but it's not ideal, I'm fairly sure the Mk3 Focus will all be as rusty as the Mk1s are now! Even the newest fiestas have paint flaking off around door hinges and boot as well. And they're still full of orange peel from the factory. But then I suppose if you want German paint quality, you have to pay for it!
(01-06-2016, 10:08 AM)Silky Wrote: Tom, have you got the pre-facelift or facelift version?
2008, very late facelift model. It's actually newer than the Focus annoyingly haha.
Threads: 52
01-06-2016, 11:16 AM
(This post was last modified: 01-06-2016, 11:16 AM by Silky.)
And someone done a straight swap for the GTI6?
Madness, I'd get it cleaned and then sold straight away. Get the extra cash in your pocket.
Full leather?
CD Changer in dash?
Heated seats?
Well I guess some people just love old Peugeots lol! Yes it was a straight swap.
Half leather, crappy aftermarket stereo (why can't people leave originals ffs!). Not sure about heated seats, haven't looked!
Now putting a thread up for it with pics.
