Threads: 136
11
From what I understand the earlier hdi's come without this , as I'm putting the gt2052s on I want to get rid of all the egr gubbins
Is it just the case the water distribution block is different ie one port blanked off and the pipes are a different route up top which don't pass through the cooler ?
Threads: 202
58
Yep, sack it off, block both manifolds and join the pipes together.. 25mm copper pipe works fairly well if a little tight to fit in.
Threads: 136
11
Cool, I've got a purpose made joiner already lying about.
Both mani's will be blocked when the turbo goes on.
Was looking at the standard 306 egr solenoid and it's huge!
I had it in my mind there were 3 pipes going into the egr cooler heater thing, that right? Or just the 2.
I'm getting confused by the thermostat housing I think
For the connection around the back
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
can you use the cooler out and inlets to cool the CHRA?
might be worth a thought
/Toseland
Threads: 136
11
Isn't a water cooled one unfortunately, could of done it with the td04 no problem
Threads: 117
119
Only two pipes on the coolers, one in and one out. The egr valve itself is pretty huge, i *think* it's for cooling so the diaphragm doesn't die - on modern cars it's usually on the inlet end of the egr pipe, or at least not mounted directly to the exhaust mani lol.
Threads: 136
11
Ah good just the 2 pipes, happy days
