 Getting rid of the egr cooler on the back of the inlet - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Getting rid of the egr cooler on the back of the inlet (/showthread.php?tid=34046)  |
Getting rid of the egr cooler on the back of the inlet - Paul_13 - 11-05-2016 From what I understand the earlier hdi's come without this , as I'm putting the gt2052s on I want to get rid of all the egr gubbins Is it just the case the water distribution block is different ie one port blanked off and the pipes are a different route up top which don't pass through the cooler ? RE: Getting rid of the egr cooler on the back of the inlet - Jonny81191 - 11-05-2016 Yep, sack it off, block both manifolds and join the pipes together.. 25mm copper pipe works fairly well if a little tight to fit in. RE: Getting rid of the egr cooler on the back of the inlet - Paul_13 - 11-05-2016 Cool, I've got a purpose made joiner already lying about. Both mani's will be blocked when the turbo goes on. Was looking at the standard 306 egr solenoid and it's huge! I had it in my mind there were 3 pipes going into the egr cooler heater thing, that right? Or just the 2. I'm getting confused by the thermostat housing I think For the connection around the back RE: Getting rid of the egr cooler on the back of the inlet - toseland - 11-05-2016 can you use the cooler out and inlets to cool the CHRA? might be worth a thought RE: Getting rid of the egr cooler on the back of the inlet - Paul_13 - 11-05-2016 Isn't a water cooled one unfortunately, could of done it with the td04 no problem RE: Getting rid of the egr cooler on the back of the inlet - Poodle - 12-05-2016 Only two pipes on the coolers, one in and one out. The egr valve itself is pretty huge, i *think* it's for cooling so the diaphragm doesn't die - on modern cars it's usually on the inlet end of the egr pipe, or at least not mounted directly to the exhaust mani lol. RE: Getting rid of the egr cooler on the back of the inlet - Paul_13 - 12-05-2016 Ah good just the 2 pipes, happy days  |
