Project 16v #theLEMOAN
Lightbulb
Time to be moving on with technology....   Blush
So for some time I have been trying to get on with a new engine for a new project...  Idea
Back last Autumn I went and got an engine....and it was heavy and made a RIGHT mess...   Undecided
Rofl Rofl Rofl
Heres the first episode... I promise the lighting and recording should(!) get better with time!   TMI
https://youtu.be/F_T4GKURfdw
Thanks given by: Xsikid
Id love thee videos of there was a bit more... Erm.. Progress?
No offence, but I just watched the whole thing and ended it with 4 injectors removed and an understanding you're not sure what the project will be?
Episode 2; more progress PLEASE
Thanks given by: Michaelc5086
Big Grin
fair play piggy , will interested to see how you get on with this , when your broken trotters fixed off course
(10-03-2016, 06:33 PM)ginge191 Wrote: Id love thee videos of there was a bit more... Erm.. Progress?
Yeah I know man...
More of an info/intro to the new project...
There will be more to come with more progress in each one Smile
Lots of win parts
Still the wrong fuel :p
(10-03-2016, 09:00 PM)ozonehostile Wrote: Still the wrong fuel :p
No, I double checked... It's fine... It runs on dirty derv not pathetic petrol ThumbsUp
i also watched... you owe me 6 minutes of my life. x
(10-03-2016, 11:41 PM)Eeyore Wrote: i also watched... you owe me 6 minutes of my life. x
If you don't already realise how poor my videos are by now..
Sure it was still better than being a sailor boy for 6min Tongue
(10-03-2016, 06:33 PM)ginge191 Wrote: No offence, but I just watched the whole thing and ended it with 4 injectors removed and an understanding you're not sure what the project will be?
That is big progress on one of these, it took me about 4 months to get the injectors out of the 2.2 I had.
I must've been very lucky with changing the injectors in mine then haha
less capacity more valves? how much does that beasty weigh?
going mechanical or ecu?
Is kind of how I felt.
The engine sat there on the stand for about a month coz I just kept putting it off!
(11-03-2016, 02:23 PM)welshpug Wrote: less capacity more valves?   how much does that beasty weigh?
Initially was going to be 2.2 so heavier than even thr 2.1 due to the 2.2 having balancer shafts!
But with the 8v block it shouldnt be too bad!
Fuel system will come later...
if the balancer shafts are like the EW12 then its very easy to get rid of them.
Yeah then its custom mounts and making a gearbox fit as the 8v hdi gearbox doesnt bolt on.
meh, just use the ml6c.
Or just bang the head on a 2.0 bottom end with 2.0 16v RHW pistons (which I reckon may not even be required as valve reliefs were removed on later engines - need someone to measure..) and be done?? That way everything just bolts together..
The extra 180cc just isn't worth it imho for the hassle.
Hopefully found some very good second hand bearings for this and a good price on rings...
Just need to sort a headset and things can make a move on...
Ironically all the shiney parts are in place... Yet lack the normal bits needed to fit it all together!
GSF stock VR Headgaskets and Headsets, make use of the 40% off they have most weekends (it would seem) and you can save a bit.
Got HG...
Need a headset. Will look into those 40% offers!
Lashing a set of ARP's into this? Does the 16v head not suffer badly from valve float at high boost/rpm
shoudlnt need to unless he's trying to slap some silly boost into it, its much more efficient than an 8v so will makegood power with less pressure.
(15-03-2016, 06:13 PM)welshpug Wrote: shoudlnt need to unless he's trying to slap some silly boost into it, its much more efficient than an 8v so will makegood power with less pressure.
This.
Darren suffered with it...but lets be honest... We know he likes the boost.
Parts updates will come with the videos soon.
https://youtu.be/VCkDrxZ0QPE
some epic parts have arrived.... turbo is being sent to company for balancing after rebuild... general seals/gaskets etc here too... things starting to take shape...
Last video to catch up I think...
https://youtu.be/ZOg_TvWqNfc
Put some pictures up with your thead you may inspire interest!
ive given up watching videos Sad
GTI6 Info
(25-03-2016, 06:17 PM)cully Wrote: Put some pictures up with your thead you may inspire interest!
K
Just for cully Smile
Video stuff wont be along for a couple weeks... But 8v block stripped down, cleaned and painted it today. Well first coat. Crank just to come out then honing the bores.
Lacking pics I guess but...
https://youtu.be/McluZ7Xiyko
About up to date now.
Couple other projects on the go and now trying to make up for 6 weeks not earning/working.
So please be patient :-)
I agree, I'd be more interested with pictures and a good write up over a video.
Agreed
polish the sump Big Grin
