Threads: 465
114
Car Model/Spec: Vauxhall
(28-10-2015, 05:55 PM)Dum-Dum Wrote: Good to hear it goes well, a decent gain in power by the sounds of it then?
ive fitted the lightened pulley and flywheel to this engine so effectively a power gain yes
other than that it was built to standard spec with ACL main and bigend bearings
one thing i am impressed with is the Castrol edge oill, on how it maintains the oil pressure even when the temp climbs,
at all times i am getting 6.5bar above 4krpm
i need to put that to test on some track work
Threads: 465
114
21-12-2015, 10:16 AM
(This post was last modified: 21-12-2015, 10:18 AM by cully.)
car is still going well other than a fuel leak from the rubber hose on the fuel rail to which i replaced the rubber for now!
ive started the process of replacing the rubber joints on the fuel line, im going to be fitting braided fuel lines,
the main reason in doing this is to remove the 10 joints in the engine bay on the fuel line flow and return.
I am going to be replacing them with AN6 aeroquip type fittings and stainless braid ptfe 8mm fuel lines
to start off ive bought some weld on AN6 fittings
to fit these i have cut the rail end off and drilled the fitting to the same size as the rail tube
I then silver soldered the fitting to the rail
2nd fitting soldered
I had to clean up the rail and what better way of stripping the rust paint and crud
Electrolisis....
12 hours later and a quick wire brush
now for some paint
1 coat of galvanise primer
1 coat of primer
few coats of black
more to come..........
81
ffs.... make me an electrolysis setup. Everything always looks so good afterwards!
Threads: 42
28
It's just a plastic box a battery charger and some scrap metal for the anodes, and some washing soda and water.
Threads: 465
114
exactly that im using a tall bucket soda crystals and a battery charger
+ terminal clipped to some mild steel plate
- terminal clipped to the piece needing cleaning
dont use or try to clean Aluminium parts
Threads: 465
114
coat of primer....
Threads: 465
114
fuel line parts ordered...
2 X AN6 weld on steel fitting
4 X AN6 BLACK 45 Degree Swivel TEFLON PTFE Fuel Oil Braided Hose Fitting
1 X mtr AN6 5/16" 8MM Stainless Steel Braided TEFLON PTFE Fuel Hose
2 X AN6 to 5/16" 7MM - 8MM BLACK PUSH ON BARB Straight Hose Fitting Adapter
1 X AN6 15mm RED HOSE END FINISHER
1 X AN6 15mm BLACK HOSE END FINISHER
Threads: 465
114
with the top coat of black
Threads: 42
28
where are the two hose fiishers going?
Threads: 465
114
they will be used over the barb fittings into the std plastic lines
two colours for flow/return identification
Threads: 141
35
Nice work cully!
Threads: 465
114
Hmmm........
the 2 X AN6 to 5/16" 7MM - 8MM BLACK PUSH ON BARB Straight Hose Fitting Adapters
are the wrong size for the plastic hardlines
have to try a different size
Bum!
Threads: 42
28
I think you'll be converting to 8mm metal lines and using a pair of an-6 to 8mm compression fittings...
Threads: 465
114
i dont really want to go down that route but its an option if this route fails,
i want to use the std plastic hardlines from back to front and pick up on the inerwing
Threads: 465
114
i seem to be having an issue in finding fittings that fit the peugeot Plastic fuel hard line, it turns out the peugeot pipe is measured 8mm outside diameter when all pipe fittings are measured by there internal bore diameter
there are no AN6 barb fittings available for the peugeot 6.5mm internal bore pipe!
the 2 X AN6 7MM - 8MM PUSH ON BARB where to big to go into the pipe
i bought some AN6 6mm barbs these were to small
and i cant find anywhere a barb fitting between these two sizes
so...........
i have taken the AN6 7-8mm fittings and turned them down in a lath to make them 6-7mm
Threads: 541
124
Sounds like an utter ballache.
Threads: 42
28
that's why I have 8mm o.d metal pipe under my ZX with a pair of compression fittings on the bulkhead.
Is it worth the hassle? Surely new standard pipes would last another 10 years or so?
Can you warm up the piping to stretch it over the AN barbed fittings?
Threads: 541
124
(07-01-2016, 11:31 AM)Piggy Wrote: Can you warm up the piping to stretch it over the AN barbed fittings?
Definitely possible as I've done it before although advisable to only do it in boiling water rather than with fire.
Threads: 102
18
(07-01-2016, 12:17 PM)Dum-Dum Wrote: (07-01-2016, 11:31 AM)Piggy Wrote: Can you warm up the piping to stretch it over the AN barbed fittings?
Threads: 465
114
(09-01-2016, 10:59 AM)RetroPug Wrote: (07-01-2016, 12:17 PM)Dum-Dum Wrote: (07-01-2016, 11:31 AM)Piggy Wrote: Can you warm up the piping to stretch it over the AN barbed fittings?
im sure your not being serious Chris as hot water is not hot enough to get the pipe soft enough to strech it over the barb
ive binned the barbed idea as i dont like the idea on the fuel line!
I'am looking at inserts and compression olive fittings for the plastic hardline now
Threads: 202
58
Heat gun would do the job, no?
Threads: 465
114
yes im sure but would you trust a barb fitting you fecked with at 50-60-70psi with petrol running though the joint near a hot exhaust manifold ?
Threads: 101
Car Model/Spec: 306HDi 90 LX
It goes, it stops (as reqd).
Hate Housework!
Threads: 541
124
(09-01-2016, 11:03 AM)cully Wrote: (07-01-2016, 12:17 PM)Dum-Dum Wrote: Definitely possible as I've done it before although advisable to only do it in boiling water rather than with fire. im sure your not being serious Chris as hot water is not hot enough to get the pipe soft enough to strech it over the barb
I managed to do it and get the hard pipe stretched over a barb.
There was alot of brute force involved but everyone loves stuffing a fat barb up a tight pipe.
Threads: 465
114
(09-01-2016, 11:35 AM)Magenta Sunset Wrote: how does that tank work? (what's it hooked up to?)
look here for more info
http://306oc.co.uk/forum/showthread.php?...#pid406099
Threads: 16
Given 3 thank(s) in 3 post(s)
10-01-2016, 09:00 AM
Good news regarding the rust situation as all that is easy to take car of.
Sure Adam had me rip the aircon out as it was f*cked many moon ago.
What engine is going back in?
Threads: 465
114
(10-01-2016, 09:00 AM)roland rat Wrote: Good news regarding the rust situation as all that is easy to take car of.
scroll back about two pages for the engine
i refreshed a std engine rings bearings seals the works and have fitted that with lightened flywheel and pulley
the air con was still in this car when i bought it now there is none left in the engine bay as ive removed all the pipework and compressor
Threads: 101
(09-01-2016, 12:43 PM)cully Wrote: (09-01-2016, 11:35 AM)Magenta Sunset Wrote: how does that tank work? (what's it hooked up to?)
brilliant. i'm impressed
Hate Housework!
