02-11-2015, 05:57 PM
want to remove the aircon pump. does anyone know the belt number i would need?
its a phase 2 xud.
its a phase 2 xud.
xud aircon delete
its a phase 2 xud.
02-11-2015, 06:04 PM
Stick your reg in on carparts4less
02-11-2015, 06:33 PM
02-11-2015, 06:34 PM
Then change the options on the side to suit your needs...
I've just done it and it comes up with a non AC belt when I change the options
02-11-2015, 06:45 PM
(02-11-2015, 06:34 PM)Paul_13 Wrote: Then change the options on the side to suit your needs... a "non A/C" belt will not the be the same as a A/C setup with the A/C removed. It is a different length. Slightly unhelpful post to the OP I know... but at least he won't go and order the wrong one! Wishes for more power...
02-11-2015, 06:46 PM
Ask nathan he just done an ac delete.
02-11-2015, 07:22 PM
I do apologise, you're right piggy.
Sorry been a long day without a lot of sleep
05-11-2015, 01:26 PM
(02-11-2015, 05:57 PM)tysonbully2k12 Wrote: want to remove the aircon pump. does anyone know the belt number i would need? The belt I used was 1153 it fits but doesn't allow me to use the this tensioner, it gives a slight squeak when revved from cold but is quiet after 20 seconds or so. |
