xud aircon delete - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: xud aircon delete (/showthread.php?tid=32411) |
xud aircon delete - tysonbully2k12 - 02-11-2015 want to remove the aircon pump. does anyone know the belt number i would need? its a phase 2 xud. RE: xud aircon delete - Paul_13 - 02-11-2015 Stick your reg in on carparts4less RE: xud aircon delete - Mattcheese31 - 02-11-2015 (02-11-2015, 06:04 PM)Paul_13 Wrote: Stick your reg in on carparts4lesswhat good will that do? lol RE: xud aircon delete - Paul_13 - 02-11-2015 Then change the options on the side to suit your needs... I've just done it and it comes up with a non AC belt when I change the options RE: xud aircon delete - Piggy - 02-11-2015 (02-11-2015, 06:34 PM)Paul_13 Wrote: Then change the options on the side to suit your needs... a "non A/C" belt will not the be the same as a A/C setup with the A/C removed. It is a different length. Slightly unhelpful post to the OP I know... but at least he won't go and order the wrong one! RE: xud aircon delete - bashbarnard - 02-11-2015 Ask nathan he just done an ac delete. RE: xud aircon delete - Paul_13 - 02-11-2015 I do apologise, you're right piggy. Sorry been a long day without a lot of sleep RE: xud aircon delete - Nathan1305 - 05-11-2015 (02-11-2015, 05:57 PM)tysonbully2k12 Wrote: want to remove the aircon pump. does anyone know the belt number i would need? The belt I used was 1153 it fits but doesn't allow me to use the this tensioner, it gives a slight squeak when revved from cold but is quiet after 20 seconds or so. |
