01-10-2015, 07:29 PM
been away and the battery went flat on the car only ever opened with central locking as the key dont work on the doors any ideas on how i get the doors to unlock ?
oh bugger
01-10-2015, 07:38 PM
Might be able to lie underneath and pop the bonnet. Possible on 205's, I know a 306 engine bay is tighter
01-10-2015, 07:50 PM
(This post was last modified: 01-10-2015, 07:51 PM by Redordead89.)
Or if you cant get the bonnet open get someone with super skinny long arms to try get jump leads on the battery
01-10-2015, 07:54 PM
Good point, or on the starter may be easier to get to
What engine is it?
01-10-2015, 08:31 PM
depends which engine and equipment, I have managed to pull the cable on a non ac dt, I doubt its possible on anything xu/xud/dw with ac.
battery live is easier to get to than starter on most.
01-10-2015, 08:39 PM
I can pull my bonnet cable no problem, worth a shot!
01-10-2015, 08:48 PM
Bit of 'penetrant' in the key barrels maybe easier?
01-10-2015, 09:00 PM
Could try using string or coat hanger. I know you said the key doesn't work on the doors but does it work on the boot ?
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
01-10-2015, 10:04 PM
(This post was last modified: 01-10-2015, 10:06 PM by Redordead89.)
Graphite lock lube for your door barrel! Don't use WD40!!!!!
Check your key battery if no joy with all of the above???
01-10-2015, 10:23 PM
If you absolutely can't get anywhere using one of the easier, less time-consuming methods suggested you could take the front bumper off and then access the bonnet catch that way.
02-10-2015, 05:42 AM
Failing all of those suggestions.................
![]() Stage 1 HDi DTurbo Diablo 5dr, "Dee-Dee"
02-10-2015, 06:18 AM
These are depressingly easy to break in to, will send you a pm.
02-10-2015, 06:30 AM
Just dive under and jump it from the alternator
