oh bugger - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: oh bugger (/showthread.php?tid=32082) |
oh bugger - gazthegnome - 01-10-2015 been away and the battery went flat on the car only ever opened with central locking as the key dont work on the doors any ideas on how i get the doors to unlock ? RE: oh bugger - Paul_13 - 01-10-2015 Might be able to lie underneath and pop the bonnet. Possible on 205's, I know a 306 engine bay is tighter RE: oh bugger - Redordead89 - 01-10-2015 Or if you cant get the bonnet open get someone with super skinny long arms to try get jump leads on the battery RE: oh bugger - Paul_13 - 01-10-2015 Good point, or on the starter may be easier to get to What engine is it? RE: oh bugger - welshpug - 01-10-2015 depends which engine and equipment, I have managed to pull the cable on a non ac dt, I doubt its possible on anything xu/xud/dw with ac. battery live is easier to get to than starter on most. RE: oh bugger - Matt - 01-10-2015 I can pull my bonnet cable no problem, worth a shot! RE: oh bugger - Toms306 - 01-10-2015 Bit of 'penetrant' in the key barrels maybe easier? RE: oh bugger - andyyy - 01-10-2015 Could try using string or coat hanger. I know you said the key doesn't work on the doors but does it work on the boot ? RE: oh bugger - Redordead89 - 01-10-2015 Graphite lock lube for your door barrel! Don't use WD40!!!!! Check your key battery if no joy with all of the above??? RE: oh bugger - RetroPug - 01-10-2015 If you absolutely can't get anywhere using one of the easier, less time-consuming methods suggested you could take the front bumper off and then access the bonnet catch that way. RE: oh bugger - highwayman306 - 02-10-2015 Failing all of those suggestions................. RE: oh bugger - Poodle - 02-10-2015 These are depressingly easy to break in to, will send you a pm. RE: oh bugger - Jonny81191 - 02-10-2015 Just dive under and jump it from the alternator |
