Threads: 27
2
Car Model/Spec: 306 Rallye
Given 1 thank(s) in 1 post(s)
Not really done much to the rallye as recent apart from raise the rear 10mm. I have bought a new clutch, xsara steering rack, tre, ball joints, arb bushes and soon to get a new gear box and driveshafts. Haha.......all this due to a slight noise.
306 Rallye giving people a surprise because they think shes a 1.6 ;-) Silly people
Threads: 3
7
Threads: 27
2
Its odd sounds like a grinding wine but only at low speed. Also feels like its stuffing from diff play? My clutch is duff tho haha
Threads: 27
2
So finally got around to sorting the car..........
God it was a back ache but it was all worth it. Fitted a new clutch, xsara rack with new inner and outer arms, gearbox with new selector bush plus driveshaft seals and some front arb bushes. All I can say is what a different beast it is!!!!!! It feels completely different it now responds when I put my foot down and the turn in is bloody mental. I now need to learn how to drive it again before I stack it like i almoat did this morning hahaha.
Once again I was far to busy to get any photos but I will do soon
Threads: 27
2
Not done much to the beasty really use been enjoying her really. At one point I thought I was going to have to sell her due to being a tit speeding but thank the gods I dont have to. Recently got rid of the annoying noise I had after replacing the drive shalfs and I have now just started to do some clean up work.
Threads: 136
11
Glad the shafts sorted the noise out
Threads: 27
2
Threads: 541
124
Looking impressively clean under there mate
Threads: 136
11
Looking goooooood
well glad you didn't get banned!
May need your hand polishing the gti again!
Threads: 15
2
Car Model/Spec: XSi
Cleaning? Really?
You've plummeted in my eyes young man...
P1 XSi track car
2.4 LWB T4
Threads: 27
2
18-05-2015, 02:29 PM
(This post was last modified: 18-05-2015, 02:31 PM by hovis16.)
(15-05-2015, 08:32 PM)Paul_13 Wrote: Looking goooooood
Sounds good paul
(15-05-2015, 09:51 PM)adam b Wrote: Cleaning? Really?
Yeah gotta save for new bits adam tho I did order a solid aux tension pullie today
Threads: 476
81
Is that primed and painted under there? Sprayed or brushed?
Threads: 27
2
krusted, primed by hand, painted by hand, then spray then laquered. Got rustbullet to attack the front cause that is prone to more damage stones, salt etc.
Threads: 27
2
21-07-2015, 08:49 PM
(This post was last modified: 21-07-2015, 08:53 PM by hovis16.)
Well its that time again Rallye tidy time. After having loose side skirts for good knows how long i decided to remove them so I can finish derusting. I then got carried away and removed the wing
Next job is to find some new clips and attack the sill. Its looking good so far.........time will tell
Threads: 581
195
Dedicated. Im just living in bliss knowing that if i can't see rust, its not there
Threads: 61
11
(21-07-2015, 08:57 PM)Niall Wrote: Dedicated. Im just living in bliss knowing that if i can't see rust, its not there
Me too
Breify saw you at pugfest mate,car look really quick and clean.
Us lot need to do a trackday so somthing
Threads: 27
2
22-07-2015, 08:33 PM
(This post was last modified: 22-07-2015, 08:38 PM by hovis16.)
Did a little after work today. Thought id start off where I no surface rust is. God this body shit is a bitch to get off if is rust free. If its not rust free it just peels off with a little help
only way to stop it getting everywhere was to go tribal
Threads: 48
4
(22-07-2015, 08:33 PM)hovis16 Wrote: only way to stop it getting everywhere was to go tribal
Fecking awesome. Exactly what's needed though. Yes,the underseal stuff that seams to be everywhere sticks to the shell pretty damn well.....angle grinder, wire brush, flap disc thing for a grinder.....gets there in the end but is a shit of a job, especially if you are on your back on your driveway.....still having the physio on my shoulder!!!!
Threads: 581
195
Threads: 27
2
23-07-2015, 08:38 PM
(This post was last modified: 23-07-2015, 08:43 PM by hovis16.)
Threads: 48
4
Dude, the bare metalling of the underside is an epic task. Properly worth doing it but do not f*ck yourself up physically like I did. Just not worth it.
Threads: 136
11
That track rod end is rusty ;p
Threads: 30
5
Car Model/Spec: 306 HDi Dturbo 5dr
Country:
I was thinking that too...and the arb nut
Threads: 27
2
27-07-2015, 06:07 PM
(This post was last modified: 27-07-2015, 06:16 PM by hovis16.)
Managed to get some more work done on the rallye Saturday as it was a nice day. Managed to burn out two grinding wheels in the process but it was worth it
Most of the front cage is now out. Now in the process of finding a new carpet and a complete dash to flock. Also all my goodies turned up
Oh yeah and became an imperial guard for the day
Threads: 48
4
What's your plans for protecting the underside?
I see electrox zinc primer as well as rust bullet in your pile.of stuff!!
Threads: 27
2
The plan is to use the electrox for the cage plates, feet and any other small part the may require it. I will then use the rust bullet for the the rest of the job. The rust bullet will then be flattened and coated in black paint to give it a nice shiney none sticky finish
Threads: 27
2
16-09-2015, 07:16 PM
(This post was last modified: 16-09-2015, 07:24 PM by hovis16.)
Been a while since i've posted anythinv due to work. But i've been a busy bee with the car. First after removing the wing I decided to remove the front end
While at it I also gave the arches a clean
Threads: 27
2
16-09-2015, 07:55 PM
(This post was last modified: 16-09-2015, 07:57 PM by hovis16.)
Threads: 136
11
That's going to be proper loud without that sound deadening!
Threads: 27
2
It is a little bit lol. Hence why I fitted some underlay otherwise i'd be enjoying the rumble haha
