Threads: 591
54
I'd say they have given you one wrong one basically.
Threads: 42
28
that's fine, just put it on the outside.
Threads: 21
3
Car Model/Spec: Stage 3 HDi
If the ones that came off had a dimple against the piston then they were fitted wrong
Threads: 18
Car Model/Spec: 306 2.0 HDI
Thanks for the replies, ill just make sure the one with the dimple goes on the outside saves the hassle of sending them back
But yes I'm pretty sure the bump locks between the piston so looks like the older pads were fitted incorrectly
Threads: 591
54
Afaik the old ones were fitted right...
Not sure what Hdi-Power is on about tbh
Threads: 21
3
19-08-2015, 03:54 PM
(This post was last modified: 19-08-2015, 03:55 PM by HDi--Power.)
The bit that sticks out fits in the piston, the odd one that he has in his set must go on the outside, remember the dimple is the hole. so his old ones were fitted incorrectly.
Threads: 202
58
I think Piggy's misread the OP, took me a minute then TBH.
Threads: 202
58
Meh, it's just an R-clip, as long as there's a pin in there it'll stay in (I see loads with split pins in). Just make sure there is something in there, otherwise your pads will go walkies.
Threads: 591
54
Yes I do have my dimples and nipples mixed up.
May need to re-evaluate my bedroom tactics.
Threads: 18
Just tried putting the pads back on, but they don't fit? I've rewound the piston a lot and they still seem to be like 2/3mm too big to go back on. Any ideas?
unattatched the handbrake cable. This is whilst the rear beam is off the car.
Threads: 386
87
Wind the piston back further lol... The locator lump is definitely in the cut-out yeah?
Threads: 42
28
yeah, needs to go back more
Threads: 476
81
Car Model/Spec: 306 Rallye
wind it in and pull the slider around?
Threads: 18
Ill give it a good wind again tomorrow and see if thats it
Threads: 18
29-08-2015, 12:39 PM
(This post was last modified: 29-08-2015, 12:52 PM by 306rhys.)
Yeah sliders are free, will give it ago now
Will clamping the piston back in work?
Threads: 386
87
The piston needs to be turned back in, clamping it won't do anything.
