No voltage at tank lift pump
2.0 HDI would not start.I connected a spare battery to the terminals on the lift pump and the car started and ran fine although not a permanent solution. I have ordered a new fuel pump relay £16.50 as it is worth a punt. Are they under the ECU. If this does not solve it what can I do? As a worst case could I take a 12 volt  feed from the battery to the lift pump with a switch that I put on when the car is running? Would that burn out the pump? I apologise if this has been covered elsewhere.
could be.........
ign switch,
fuse,
impact switch triggered,
double fuel relay behind ECU,
ecu itself,
bulk head connection under windscreen wiper motor to cabin,
connectors to the right of the centre console above passenger feet,
connectors at the pump,
pump itself,
any of the cableing in between,
that should give you something to start on Wink
GTI6 Info
Thanks given by: KevinTW
(12-06-2015, 04:13 PM)cully Wrote: could be.........
ign switch,
fuse,
ecu itself,
pump itself,
Is the 12 volt feed from the battery via a switch a bad idea? Assuming the new relay is ok if there is still no power at the pump can I run a new feed straight from the relay and if so which wire do I splice into?
Anybody know where the impact switch is, what it looks like and whether I can bypass it.
Impact switch is on the passenger side inner wing, near the base of the windscreen, red rubber cap. If it's been triggered you can reset it by simply pressing the button (top face of rubber cap), you'll feel it click with little pressure. If that's down, test the terminals for resistance - if there's no/very low resistance you know the switch isn't the issue.
Check each point on the power supply route for power, if there's an issue with the wiring you'll find a point where everything downstream is dead, so work forwards from there.
This happened to my misses 206 messed about for ever with it and turned out just to be a bad earth
  Won't start, think lift pump. daveylennon93 11 3,636 23-01-2017, 09:36 AM
Last Post: daveylennon93
  no power to lift pump thanhhungone 4 2,119 20-01-2016, 06:25 AM
Last Post: Poodle
  tank pump pug306driver 1 850 27-09-2015, 08:31 AM
Last Post: Uberderv
