The Astor Platinum Onyx
Ok little bit of a update
The bodged up decat split in half the other day so went round bash's to get it welded up.
He did a great job and even let me do some welded lol
So running really well at the moment even been using it as a daily this week.Done 315 miles for 50 pound so ok not the 45mpg the focus gets but still pretty good.
[Image: Cn91r40h.jpg]
 So give the astor a clean before we head down to Kent tomorrow to do the rolling road
[attachment=23498][attachment=23499]
The question what's it going to make ??
Power mods are Decat,Magnex cat back, rich w flywheel,alloy pulley,K&N induction
Good luck. 179bhp I guess.
155bhp. S16 power Smile
162hp
None of your modifications will really make you gain power, you might have lost some mid range if anything.
Depending on the dyno and the cam timing anything between 162 and 172 is good, torque 142 -155
P1 XSi track car
2.4 LWB T4
low torque I rekon by the mods, so 140ish but they make healthy bhp top end standard so 173bhp Smile
Well it only made 167.7 but looking back on it I'm pretty happy to retain its standard power and the mods are all breather so it's standard untouched engine essentially
[attachment=23504]
https://youtu.be/wEp98NKcqME
[attachment=23505]
[attachment=23507]
Would be intestine to see matt or zakk's printouts aswell just to see how much toque I lost though the decat
I would say thats a decent result, seems to be pretty accurate. Looks like a very clean dyno set up, Cant imagine that would want to many smokey dervs in there
(01-06-2015, 12:36 PM)Frosty Wrote: I would say thats a decent result, seems to be pretty accurate. Looks like a very clean dyno set up, Cant imagine that would want to many smokey dervs in there
They where 2 skoda 130 tdi thing making plenty of smoke Big Grin
guys running it seems pretty good lads so don't see where they wouldn't.
a 40bhp trans loss!?
40bhp is about right my 205 was the same.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
You are looking at it wrong piggy. It's a maha dyno not a hub dyno and as such measures coast down figures rather than guessing at the fly figure using crappy maths.
P1 XSi track car
2.4 LWB T4
(01-06-2015, 04:27 PM)adam b Wrote: You are looking at it wrong piggy. It's a maha dyno not a hub dyno and as such measures coast down figures rather than guessing at the fly figure using crappy maths.
Thats how most dynos do it in my experience of using them.
Just seems quite high.
Mine was calculated at 12bhp loss using coast down figures!
The dyno that a few of us from down here use at tipton seems to be about 20% lose from the flyweheel figure to the wheel figure
12hp loss seems far too low tbh James, we had a couple of dyno days at college and losses were mostly around 20-30hp for 'normal' cars. (Golfs, Saxos, Clios etc). Was a Mini there with 40bhp ATF and 20bhp losses which was a laugh. lol Golf 130TDi had about 25bhp loss iirc.
exactly my argument with "flywheel figures"
My at the wheel figure was 206bhp.... but 218bhp at the "fly" by coast down figures!
I don't have a picture of my gti6 graph on my phone but I'll upload it when I'm next on the laptop. Id quite like to see the side by side cat and decat graph
(01-06-2015, 05:10 PM)Frosty Wrote: The dyno that a few of us from down here use at tipton seems to be about 20% lose from the flyweheel figure to the wheel figure
Mine was done at Tipton a few years ago and was 40bhp loss
05' Evo 9 IX GT
Team eaton.
(01-06-2015, 05:30 PM)Piggy Wrote: exactly my argument with "flywheel figures"
Would be much better if everyone (inc manufacturers!) used ATW figures tbh, still not perfect but much closer than anything 'guessed' ATF.
Very true but people will always say the higher number as it sounds better lol
But this isn't a guessed at the flywheel figure... No point comparing dyno figures either.
Anyway I'd check your cam timing as the torque figure is pretty low. If it's not been skimmed you'll have more out of that car yet - speak to welshpug about it at Pugfest or fcs. Decat doesn't hurt it that much.
Must get my car on our dyno in work!
P1 XSi track car
2.4 LWB T4
torque does look a bit low, is that 166nm? peak rpm of power and torque is a bit high which typically incucates slightly retarded cam timing, power should peak at 6500 iirc.
bring the cam timing forwards will bring up peak torque.
im not convinced at all with the figures from hereford, decent looking setup but difficult looking to replicate the results given.
wasnt Matts black rallye 165bhp at the wheels!? And his is high mileage, very little care for the engine!
(01-06-2015, 10:38 PM)welshpug Wrote: im not convinced at all with the figures from hereford, decent looking setup but difficult looking to replicate the results given.
Of course you're not...what would a post from welshpug be without picking on something and thinking you know better?!  Dodgy
It's because he is usually right. Hate to say it Wink
Just always comes across as lacking tact, our Meirion...
P1 XSi track car
2.4 LWB T4
I didn't suggest in any way that I knew better lol
but I.m.e there really shouldnt have been that wild a variation in figures especially with "standard" engines.
Decent result Sam, left u wanting more though? Better than my rallye's last go on the dyno with the faulty lambda sensor anyway!
CLUB RALLYE
(02-06-2015, 06:07 AM)Piggy Wrote: wasnt Matts black rallye 165bhp at the wheels!? And his is high mileage, very little care for the engine!
TBH with these XU10s i see a lot of varying figures for standard engines regardless of milage or care. It could be just a coincidence and its different dynos or it could be they are just the sort of engine that is pretty hard against abuse and age/mileage related damage.
You can only compare results from different dynos by the shape of the curve
Fast ford did a test where they drove round 5 different dynos in an afternoon (so the car was the same, same condition, same weather etc) and there was about a 10% difference between the highest and lowest.
(02-06-2015, 07:49 AM)welshpug Wrote: I didn't suggest in any way that I knew better lol
if it was just his there that day, I would say it was high...
But Ozones was there and was a good figure.
And then there must have been 30 odd other cars, quite a few standard, different engines and marks and they all did as expected, including a new fiesta st and clio sport which both were bob on the money
  Phase 1 GTI6 - Onyx ginge191 2 3,107 01-04-2026, 08:48 PM
Last Post: ginge191
  Matts Onyx Rallye. 182.1bhp & 154.5ft/lb Wilwoods & axle arrived! Welding finished! Matt-Rallye 420 282,643 11-03-2017, 08:23 AM
Last Post: Matt-Rallye
  Platinum Silver S1 306 HDI MY95 16 12,655 17-07-2015, 12:21 PM
Last Post: MY95
