Noises!
Noises!
Hi everyone.
This is a bit of a funny topic as the best way to describe it is that when im in 3rd or 4th gear and i take off the throttle and let the car slow down its sounds like a airplane landing or taking off!! Ive had a few guesses from people on facebook to what it might be but i really have no idea!
Ive got a hdi btw.
Thanks
Stop driving past the airport.
Probably the gearbox though tbh.
Haha now that would make sense.
Im glad u said gearbox ive been told that too.
What exactly would it be wrong with the gearbox?
A bearing somewhere. Its fairly common though, particularly the diff bearing. If its just a noise I'd leave it until you can feel it tbh, I haven't had a 306 with a silent gearbox so far lol.
Ah i see thanks for that, ill just put the radio up a bit loader for now then.
What kind of effort isit to change the gearbox??
Have you checked the oil level?
Has it got the right oil in it?
I be checking both those things before getting the box off!
Is it a more of a whine or a roar!?
Yeah checked the oil level thats fine and yeah same oil as I've always used.
Its more of a whine and im coasting down.
Do hdi's not normally have a whiny gearbox? Mines had an so did a few others I know, does it disappear when you put the clutch in?
Yeah could be released bearing on clutch if it goes away when you dip the clutch
No nothing happens when i put the clutch in, just get it all the time when decreasing speed.
Clutch shouldn't make a difference, its the diff bearing, and yes they all do it these days lol.
If theres a difference with the clutch, its likely to be release bearing....I wouldn't leave that though, they can create a mess when they finally fail...
Hi Guys
Finally after a mind numbing process of trying to discover this noise it is now gone :-)
After spending nearly 400 for the box to be re-furbed which i was told was the problem, then to have the box come back and the noise was still there but a lot louder!!
To find out from a different garage that it was a bloody wheel bearing all along!!
Not a very happy situation but all sorted now and running as silent as a mouse.
  Noises LewisG 4 2,702 22-02-2014, 08:22 PM
Last Post: LewisG
Sad Troubling noises/dead turbo/need help Slam Wagon 12 6,979 14-04-2013, 04:12 PM
Last Post: Slam Wagon
  Timing / Cam noises from HDi 2.0 nauest 27 15,382 29-04-2012, 08:03 AM
Last Post: nauest
