Noises
Ive got a clicking/tapping noise coming from the gearbox although when i put the clutch pedal down the noise goes away. ALso when I pull away the front passenger side wheel shakes vigorously. any ideas? Gearbox on its way out or?
Sounds like release bearing the noise if it goes away when you put clutch in but could also be a f*cked gearbox if it's doing that to the wheel that or the wishbones
Team Doesn't own a 306
I think it might be the gearbox as I have trouble sometimes getting into 3rd gear you have to double clutch it. Also get a whining noise in 5th gear.
Yea box is f*cked no doubt about it sounds like its had no oil in
(22-02-2014, 08:18 PM)Danny2009 Wrote: Yea box is f*cked no doubt about it sounds like its had no oil in
Yeah that would make sense as the previous owner also let the engine oil get low. I topped it up though before the journey home.
  Noises! Nicks306 12 5,256 31-01-2015, 08:27 PM
Last Post: Nicks306
Sad Troubling noises/dead turbo/need help Slam Wagon 12 7,651 14-04-2013, 04:12 PM
Last Post: Slam Wagon
  Timing / Cam noises from HDi 2.0 nauest 27 16,693 29-04-2012, 08:03 AM
Last Post: nauest
