Harness bar
Harness bar
(03-11-2014, 12:51 PM)Grant Wrote:
(03-11-2014, 12:24 PM)Jonny81191 Wrote:
(03-11-2014, 12:04 PM)kentiiboii Wrote: Didn't grant bolt his through the arches with a plate on the other side?
Yeah, it ruined his tyres as they caught on the plate IIRC.
Seriously, if you're going track spec and putting buckets in, fit a half cage as a minimum. Otherwise, fit reclining buckets or s16 seats to hold you in, and use the standard seatbelts.
I used bolts that were too long lmao
They were fine when sorted out. I've had the car supported from a block and tackle, off the garage roof using that harness bar just to prove a point. Nothing budged.
I would like to see a pic of that lol
bear in mind that, also, some insurers WONT insure you with a cage fitted (premium choice being one)
/Toseland
(04-11-2014, 08:07 PM)mossy1985 Wrote:
(03-11-2014, 12:51 PM)Grant Wrote: [ I've had the car supported from a block and tackle, off the garage roof using that harness bar just to prove a point. Nothing budged.
just remember the impact weight in an accident can be many-many times the weight of a car suspended
and it will rip bolts through steal like a knife through butter
get it done properly or dont bother your life and your passengers depends on it
  door harness on service box bashbarnard 3 2,743 11-05-2017, 06:16 AM
Last Post: bashbarnard
