Threads: 343
15
Given 3 thank(s) in 3 post(s)
So as above I've been having issues with the hand primer sucking flat, originally on my standard fuel lines I had air getting in replaced the hand primer and fuel filter after this it sucked flat constantly so, took in tank strainer out was full of carp so cleaned it out, but it continued so I removed it and replaced it with a one way valve, fast forward a week started sucking air in again so quickly put 10mm lines on.
And it's sucking the 10mm hand primer flat checked the tank strainer again and it's clean so I'm out of ideas apart from primers being shite but they was all brand new.
So can any one shed some light on it? It's running fine with out the hand primer.
I assume this is an ebay 10mm primer??
I had same issues.
Hence why I went for a 12mm primer as the 10mm ones are so restrictive internally
Threads: 343
15
(30-10-2014, 12:36 PM)Piggy Wrote: I assume this is an ebay 10mm primer??
I had same issues.
I bought a 12mm and the internal size was about 6mm on it this 10mm one is about 8mm
Seems to me ebay ones are shit wonder if I can find a quality one from some were local
Mine cost about £9. Nice billet alloy ends
Threads: 343
15
(30-10-2014, 12:45 PM)Piggy Wrote: Mine cost about £9. Nice billet alloy ends
Any chance of link? Don't mind spending if I'm getting a decent one the ones I bought were about £5
Threads: 10
(30-10-2014, 12:47 PM)Chris_90 Wrote: (30-10-2014, 12:45 PM)Piggy Wrote: Mine cost about £9. Nice billet alloy ends
I used this one on mine and it worked fine.
Link
Threads: 343
15
(30-10-2014, 01:49 PM)PartyJas Wrote: (30-10-2014, 12:47 PM)Chris_90 Wrote: (30-10-2014, 12:45 PM)Piggy Wrote: Mine cost about £9. Nice billet alloy ends
Link
That's for 8mm
My one is like that but 12mm
This is the one i think...on discount too:
http://m.ebay.co.uk/itm/290402081065?nav=SEARCH
Threads: 343
15
(30-10-2014, 03:54 PM)Piggy Wrote: My one is like that but 12mm
The ones I've got look identical, not sure about spending another £6 and it could still do the same
Threads: 226
24
Car Model/Spec: A3 TDi
Why do you want a primer? I just ditched mine lol
Threads: 343
15
(30-10-2014, 05:55 PM)Tom Wrote: Why do you want a primer? I just ditched mine lol
To fill fuel filter when I'm out in sticks with no light, rather than flattening battery sucking the fuel though
All tho I do have a fract (how ever it's spelt) pump I could put in that'd prime it up nicely but more places for it to get air in if it decieds to leak.
Threads: 87
48
I'm tight but £6 Chris, stop fcuking around lol
I assume you never aired up the system then... You'd be stranded if you did...
Threads: 343
15
(31-10-2014, 10:37 AM)Mattcheese31 Wrote: I'm tight but £6 Chris, stop fcuking around lol
I no its only £6 for that one but I've spent about £20+ on primers for same thing to happen every time
(31-10-2014, 10:52 AM)Ruan Wrote: (30-10-2014, 05:55 PM)Tom Wrote: Why do you want a primer? I just ditched mine lol
My point exactly think I'll fit my facet pump to the system that should prime it up in the event of an air leak.
I'd strongly advise against, it'll cause restriction if you don't power it... As you're seeing with the primer sucking down...
If you power it, it'll send the internal pump pressure insane.
If you must, fit the pump but ensure you use a pressure regulator set to a VERY low pressure, doing so really messes up the internal pressure of the pump, affecting injection timing and all sorts of other things... These pumps aren't designed for it, they're very finely balanced in terms of pressure on inlet and outlet - that's how the entire timing system of the pump operates!
If you do I can see a thread in <1 weeks time "my car clanks really loudly all the time and is slow as shit"...
Threads: 343
15
Ha ha fair enough that's out if window then, best try.find a quality hand primer.
Threads: 28
Car Model/Spec: Anything but a 306
(30-10-2014, 12:16 PM)Chris_90 Wrote: took in tank strainer out was full of carp
Hope you had a licence to catch them...
Matt-Rallye Wrote:Norledge for prime minister. Poodle Wrote:I reckon Norledge has got it on the head mind. Matt-Rallye Wrote:Norledge gets my vote tbh.
Threads: 343
15
(31-10-2014, 05:14 PM)Norledge Wrote: (30-10-2014, 12:16 PM)Chris_90 Wrote: took in tank strainer out was full of carp
Threads: 41
Car Model/Spec: Dtractor
Given 6 thank(s) in 6 post(s)
(31-10-2014, 04:00 PM)Ruan Wrote: I'd strongly advise against, it'll cause restriction if you don't power it... As you're seeing with the primer sucking down...
Correction,
"my car clanks really loud and is slow as shit UNTIL 7,000RPM"
