Anyone got a t2 to hand?
I'm in Austria at the moment, and I need to order some flexi intake piping so that it arrives by the time I'm home. I need it to be the correct internal diamteter to fit onto the inlet of a garret t2. I'm guessing its around 2inches but I'd quite like an accurate measurement.
Could someone please measure the inlet diameter for me? Rep will be given!
[Image: 20120704_212316.jpg]
Got a k14 and gt15 in the garage. Typical. Il measure them both in the morning though because they might all be the same...
k14 is 47mm
Funnily enough i have one in my boot :p ill measure it tomorrow for ya
(30-12-2012, 10:38 PM)parrotveasey81 Wrote: k14 is 47mm
Thanks for getting the measurement I would have thought t2 would be very similar. Accidently repped you twice hope you don't mind!
(30-12-2012, 10:42 PM)Parksy87 Wrote: Funnily enough i have one in my boot :p ill measure it tomorrow for ya
Cheers be great if you could Smile
Bump! Anyone?
I used 2" pipe on mine. Wasn't snug snug but fit with no issues with a clamp.
Oki doke thanks. That probably means its the same as the k14 so ill get some pipe with an ID of 47-51
I used 51mm ID with no issues. Also used it for the outlet.
Stage 2 XUD Sedan
Just ordered some 51mm 2 ply neoprene/silicon stuff with the reinforcing wire in it. Should do the job. Will be tricky joining the filter on though, might have to be taped to start with!
(01-01-2013, 09:12 PM)Ben Wrote: Just ordered some 51mm 2 ply neoprene/silicon stuff with the reinforcing wire in it. Should do the job. Will be tricky joining the filter on though, might have to be taped to start with!
How so? Do you not have a coupler you could use?
Ideally you want the inlet to open up to 3 or 4" by the time it reaches the filter..
Don't think I have anything suitable I'm going to have to order a couple little bits, will have to wait a week or two though.
I think I have a couple of 90 degree elbows and some pipe from my old filter setup mate, took it from 2" at the blower to 3" at the filter.
Let me know if they're any use to you, my car's always been defiltered so didn't actually get any time on the road. Nearly new cone filter too.
(01-01-2013, 09:48 PM)cwspellowe Wrote: I think I have a couple of 90 degree elbows and some pipe from my old filter setup mate, took it from 2" at the blower to 3" at the filter.
Any pics of it in the bay? Could well be interested as it'll save buying it new.
Yarp, two mins
[Image: DSCF1883copy.jpg]
[Image: DSCF1869copy.jpg]
Looks good, my filter is going to be behind the other headlight, but some of those bits could still be useful. What are the individual bends and pipes you have, and how much would you want for them? I think my filter will be the same size, was it a 14 quid eBay jobby?
Yeah was £15-£20 or so, can't remember. Got some pics on the camera I'll upload when home. I've got two 50cm lengths of 63mm pipe, a 63mm elbow and the filter, never ran on the car.
Would say £25 posted for the lot if you want it all, or £15 posted for the pipes and elbow
Sounds good, ill have that off you I think. How did you get from the 2inch flexi pipe to the 3inch metal then?
I was wrong in my maths, would appear I used 2.5" pipe to the filter. I thought i'd gone 3" but apparently not
[Image: DSCF0277.jpg]
[Image: DSCF0274.jpg]
[Image: DSCF0273.jpg]
Ok, what did you use to connect that 2.5inch pipe to the 2.0inch turbo inlet?
I used a silicone elbow, you can get reducer ones that step down in size, so 63mm ID at one end and 50mm at the other end
Could you sell that reducer as well or are you keeping it?
If I can find it you can have it. Not quite sure where it went to though! I didn't use it for the FMIC though I don't think, so it should be about somewhere
Cool be good if you could find it let me know after you've had a look?
Will do mate. Not sure if i'll be there tomorrow but def will be Saturday
Any luck with the search?
Yeah just back mate, couldn't find the adapter im afraid so you'd need one from the likes of ASH on eBay if you still wanted these.
Ok no worries, ill just take the pipes and elbow off you I think, ill leave the filter. Same PayPal as I used for the group buy?
Yeah that's fine mate. Same PayPal please, and I'll get them to you by Wednesday
Payment sorted. Thanks ill let you know when they arrive.
  Hand primer sucking flat Chris_90 18 13,191 01-11-2014, 10:25 PM
Last Post: Dave
  Hand primer Mart 3 2,795 13-01-2012, 03:10 PM
Last Post: Mart
