Primer bulb sucked in and wont return?!
Driving along,lost power.
will start after alot of turning over,then when moving off will pull ok for 5 seconds then just shut down.
Primer bulb is fully sucked in!Wont return to normal position
Any Suggestions
fuel tank strainer pickup is blocked or kinked damaged pipe from the tank to the primer
  Priming Bulb Not Holding Pressure leswoollam 4 5,145 30-10-2020, 07:22 PM
Last Post: welshpug
  Xud9 White smoke and primer wont stay hard Donny165 5 5,560 13-07-2020, 12:22 AM
Last Post: ekjdm14
  Leaky diesel return line Iaitoo 6 4,170 23-01-2016, 11:37 AM
Last Post: Iaitoo
