Threads: 47
Car Model/Spec: 2001 lx hdi estate
Hi pug boys.
Does anyone have a picture/guide on how to remove stop solenoid on hdi injector pump. Have tracked down my start probs to this, help appreciated.
Cheers
Threads: 371
29
Car Model/Spec: ford fiesta
There isnt only a sensor on it. Stop solinoids are for older diesels like xuds. Newer hdi stop injector pulses hence no fuel.
Threads: 14
Given 6 thank(s) in 6 post(s)
ye there is no stop solenoid on the hdi pump just a regulator valve.
what problem are you having?
Has it had a new lift pump or hp pump? If it was the hp pump then i'd be looking at the lift pump. You want to get it on live diags really and see what's happening when it doesn't start, will give you a much better idea of what the problem is. But then a proper mechanic would have done that for you already rather than making bad guesses...
Threads: 14
if it takes priming to get it started i would be looking for leak from some where rather than sensors.
As above, if priming twice helps then it follows that you've got an issue with the low pressure circuit, rather than anything on the hp pump. My first call would have been the lift pump too tbh, was it a new one that was fitted? Perhaps worth taking a look at the fuel relay and filter housing.
Threads: 136
11
My fuel relay is failing.
The lift pump doesn't always prime first go.
