1998 gti6 Axle on 2001 HDI
Just want to check will the entire axle of a 1998 gti6 axle fit on my 2001 306 HDI? Also is there any differences in the two axles such as torsion bars brakes etc?
Thanks
Should be the same I think!
Be slightly firmer. But will fit no problem. Assuming your hdi has discs which I think nearly all ph3 hdi's had
yeh if both have discs its a decent swap. Should be a much stiffer beam too.
All HDi's have rear discs. HDi DTurbo's use a GTi beam so if you have anything other than a DTurbo, it'll lower the height slightly and be firmer.
However the '98 beam probably has the brake bias valve which yours wont (can just be bypassed) BUT may not have the ABS sensors?
  B4/Eibach with GTI6 Rear Axle MY95 3 2,839 24-01-2017, 10:49 PM
Last Post: MY95
  GTi6. beam bearings and stub axle measurements Ben_w 14 8,151 01-06-2015, 05:22 PM
Last Post: Ben_w
  Gti6 axle on HDI? LewisG 5 3,774 08-03-2014, 04:19 PM
Last Post: LewisG
