Threads: 17
4
Car Model/Spec: 2.0 xsi Diablo
Hi everyone
Has any one removed a headlining and painted it
If so how did it go
Or what is people's opinions on this
Threads: 16
Car Model/Spec: 306 GTI 3.0 V6
Just did mine as removed sunroof and replaced with a carbon fiber blank.
I went to use fabric dye but was a waste of time as didnt cover the bit I tested on very well so used rattle cans and it now look wicked
Threads: 17
4
(22-08-2014, 02:59 PM)calibra306 Wrote: Just did mine as removed sunroof and replaced with a carbon fiber blank.
So painting works I've thought about it I re-dyed my rear seat and thought head liner wants doing but wasn't sure if it'd work
thanks
Threads: 16
Spray paint So it gets into the fibers. Heard people say it will go crusty but it come out fine.
Threads: 17
4
I'll take it out this weekend and get some satin black on it see how it goes
Thanks again
Threads: 581
195
Moved this to the correct section
Dont paint it. They go horrendously crusty and horrible. If i was you, buy some material and some automotive spray glue and recover it. its really not that difficult and the finish is 10 times better
[attachment=18530]
Thats a small photo of mine done in fake suede.
Threads: 17
4
Thanks it looks good was it hard to remove
Threads: 79
17
Car Model/Spec: Down and out HDi racestate
Pull the door rubbers down, remove the interior light panel and sun visors, pop off the pillar trims. And drop it out.
Threads: 17
4
22-08-2014, 04:07 PM
(This post was last modified: 22-08-2014, 04:13 PM by Adam-m-h.)
Thanks that's this weekend sorted
What do you think to this? my car is Diablo red
Threads: 371
29
Car Model/Spec: ford fiesta
Not a fan.of the red but I like the suede. Ive still got to get black trims on mine first though
Threads: 16
Niall. When you mention it going crusty do ya know if thats after time it being sprayed and fitted or some peeps experiance of it doing it once its sprayed or during.
Threads: 66
Car Model/Spec: 306 hdi Dturbo
Glad I clicked on this as I now know how to remove the roof lining ready for sound deadening cheers for this thread
Threads: 17
4
Thank for the advice I think I'm going for recovering option in a black leather look and painting the stereo surround and vent Diablo red
Threads: 16
What ya gonna use mate? Cloud 9
Threads: 93
8
Car Model/Spec: Stock HDi Meridian & Mk2 MX-5
Anybody got recommendations as to what material to use? Going to be doing this soonish, and wondering about how stretchy the material needs to be, i.e. would a bedsheet work?
![[Image: sigcopy-1.jpg]](http://i570.photobucket.com/albums/ss147/KEZZIEBOY/Diablo%20HDi/sigcopy-1.jpg)
Threads: 66
Calibra306 was that for me? Don't want to steal the thread but been looking at Silent coat give it a try as it's not overly chunky at 3mm
Threads: 79
17
(22-08-2014, 09:35 PM)Kezzieboy Wrote: Anybody got recommendations as to what material to use? Going to be doing this soonish, and wondering about how stretchy the material needs to be, i.e. would a bedsheet work?
Bed sheet can be a bit thin, will work but wrinkles show easy so smooth it out well. Duvet covers are a good option, usually a little weightier material than a sheet, also good for getting a pattern or design if you want something different. Suede is a good call, black keeps it nice and simple, hides and wrinkles etc well.
Material with a bit of stretch will make it easier and neater, but its not required, you may find you end up with a few small wrinkles around the tight bends like the handle reccess and the sun visor recess if your material doesnt have any stretch.
My suggestions are, get yourself a nice big workspace, some decent high temp adhesive (Trimfix on ebay), lay it all out and start with the area above the frint seats, work your way back from there leaving the edges for last, spray both the roof lining and your material with the adhesive, dont need too much or it will soak through but a good covering on both, i usually do it in roughly a foot or two sections at a time, lift the material up, spray the section, lay it back down and smooth from the middle out. Once tge centre section of the roof is done go back and do all the edges, wrapping it over the edge and gluing it down to the back will stop the edges peeling. Then trim off any excess, give it a chance to dry, refit.
Threads: 100
12
Car Model/Spec: 306 dturbo Ultra Spec
I have done about three or four of these trimfix is great stuff and worth using. Go to a local material shop and have a look around you want something nice and thick so the glue goes not come through when you stick it down. I actually have a 5 door one in the garage which I did with brown material if anyone is interested.
I laid the roof lining down and put the material over it, cut it to size then started from the back and did the worth width of the lining but around a fot at a time.
Threads: 17
4
(23-08-2014, 07:45 AM)Pompey306mark Wrote: I have done about three or four of these trimfix is great stuff and worth using. Go to a local material shop and have a look around you want something nice and thick so the glue goes not come through when you stick it down. I actually have a 5 door one in the garage which I did with brown material if anyone is interested.
Hi I was wondering how hard it is to get the the material around the sun visor recess?
Threads: 93
8
(23-08-2014, 06:39 AM)Slam Wagon Wrote: (22-08-2014, 09:35 PM)Kezzieboy Wrote: Anybody got recommendations as to what material to use? Going to be doing this soonish, and wondering about how stretchy the material needs to be, i.e. would a bedsheet work?
Awesome cheers for the advice. I've been looking at duvet covers for that exact reason, I want some sort of pattern.
Threads: 17
4
23-08-2014, 08:25 AM
(This post was last modified: 23-08-2014, 08:30 AM by Adam-m-h.)
http://s48.photobucket.com/user/adammh88/slideshow/306
For those that want to know
I first removed the lights
Then the sun visors and handles
I then pulled the rear pillar plastic down and removed the headliner from the back working forwards as I found it had a lot more glue at the front I struggled Abit near the front seat belts as the trim doesn't move that far the front plastic near windscreen were a doddle then out it came so off to fabric shop see what there is
Threads: 17
4
A few creases but I can live with that
Threads: 79
17
Nice job, unless you get material with some stretch then creases are unavoidable.
Threads: 17
4
23-08-2014, 05:54 PM
(This post was last modified: 23-08-2014, 06:01 PM by Adam-m-h.)
I think there was to much stretch in it I've also painted the front and rear light surrounds Diablo but left handles and sun visors grey unsure weather to do them red or black
Threads: 79
17
Sun visors are a bit of a pig, being covered already, theyre hard to cover and cant be sprayed. They can be flocked or replaced with cabriolet visors that ate already black but are slightly shorter.
Threads: 17
4
This was before
Threads: 93
8
23-08-2014, 08:17 PM
(This post was last modified: 23-08-2014, 08:18 PM by Kezzieboy.)
Yeah I've been wondering about the visors, mine are stickerbombed at the moment, I don't really like them anymore but can't think what else to do with them!
Threads: 581
195
Piggy flocked my visors and they look great.
Threads: 17
4
(23-08-2014, 09:13 PM)Niall Wrote: Piggy flocked my visors and they look great.
Can the handles be flocked too?
Threads: 581
195
Virtually anything can be flocked
