Manual boost controller or adjust the wastegate arm?
Going to start on my stage 2 next week was wondering what is the easiest way to adjust the boost. I've read mixed opinions on both options and I know either way is an arse of a job, just wanted other peoples opinions.
Bye Bye D-Turbo
Personally I would fit manual boost controller leave actuator in standard position and not mess with the preload. And yes not the most enjoyable job I've ever done on a car lol.
Fitted an MBC is pretty easy tbh
And once its done, you can adjust it as many times as you want with ease ThumbsUp
All go well I will be going this way soon, can someone drop me a link to a suitable mbc please. Thankyou ThumbsUp
I've got a few lad grab one when you pop up
Team Doesn't own a 306
Thanks people going to order an mbc then.
Bye Bye D-Turbo
Make sure you get the ball and spring type and not bleed
I recomend one like this
http://www.ebay.co.uk/itm/201145340805
Why spring/ball over bleed?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
Personally, I'd only ever use one of these:
http://www.ebay.co.uk/itm/TurboSmart-Boo...3f3ab926f5
They work so so much better. If you are flush, use one of these:
http://www.ebay.co.uk/itm/HKS-EVC-IV-4-E...2a40e4dda5
JP
JP
They all bleed a little....not sure on the one JP put up though.
Bleed valves cause an artificial delay on the actuator, so you end up with a slightly less responsive arrangement and boost spikes.
Yeah, they are naff tbh... A turbosmart one with a ball and spring (or even tbh some of the cheaper ball and spring ones) actually tend to speed up boost response by avoiding wastegate creep.
When I ran the electronic controller on my XUD you should have felt the difference in how it spooled up with it turned on and turned off. Much much harder and about 500rpm earlier!!
JP
JP
261526791351 check out this item number on ebay currently using phone. But I used this mbc and seems very good very happy with it.
This is the one I ordered in the end: http://bit.ly/LCfjeE it's the spring and ball type.
Bye Bye D-Turbo
  Boost controller GFB G-FORCE II loli_04 6 5,134 18-03-2017, 11:03 AM
Last Post: loli_04
  Wastegate actuator DeeTurbo 1 2,524 17-11-2016, 06:55 PM
Last Post: Poodle
  electronic boost controller ??? Donkeybubles 5 3,673 16-07-2015, 03:41 PM
Last Post: JTaylor2005
