Turbo talk.
Turbo talk.
I think that the ko3 is better if your runnin a stage 1 with a lucas pump. But if you have a bosch pump k14 will boost more than the ko3 and last longer into the revs with a gov mod on the pump. Neither are much good for serious power.
                                                      HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
Its not a power thing this motor. More my daily runner to be fair. I think ill just keep the ko3 on then.
Yeah ko3 makes for better daily anyway imo. More torqee down low.
(15-04-2014, 09:23 PM)zx_volcane Wrote: Gearbox mounting will increase lag, no doubt.
Somewhat negated by running with a VNT huh Smile
I don't suppose you even notice ?
You get nothing for free in this world, even with a vnt.
I think it would spool quicker on a shorter manifold straight off the head.
Velocity is king.
I know it's like a thumb suck guesstimate, AND that you've got a more elegant fannimold, but we're only talking a couple of hundred RPM right ?
(18-07-2014, 09:42 AM)nominous Wrote: I know it's like a thumb suck guesstimate, AND that you've got a more elegant fannimold, but we're only talking a couple of hundred RPM right ?
Yeaaaaaaah, it'll be fine. It's not exactly a preccision engineering job.
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Tom's fannimold is !! Big Grin
(18-07-2014, 10:07 AM)nominous Wrote: Tom's fannimold is !! Big Grin
Oh yeah because extensive R&D went into that thing! Rofl
S14 Zenki Build
more than you think, behind all that cut up wastepipe and duct tape were some serious engineering principles
I can't quite make out from the pics if you're t-ing into two pipes before the turbo flange or if you've got a 4 branch collector going on?
Certainly looks like you went to the effort of pairing to firing order.
(18-07-2014, 10:19 AM)zx_volcane Wrote:
(18-07-2014, 10:13 AM)silverzx Wrote: Oh yeah because extensive R&D went into that thing! Rofl
Quantum mechanic based engineering.
S14 Zenki Build
(18-07-2014, 10:22 AM)nominous Wrote: I can't quite make out from the pics if you're t-ing into two pipes before the turbo flange or if you've got a 4 branch collector going on?
It's an un-equal length 4-2-1. The cylinders are paired and come together in as smooth a way as I could manage with bits available. We tried to avoid any tight radius's and made a proper 2-1 collector.
As Tom says, velocity is king :-)
K14/T2 are basically the same turbo, just T2 can run more boost.
K03/GT15 are basically the same turbo, just the K03 can run more boost.
Go bigger, TD04.
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
Quite happy with the standard ko3 on mine atm . maybe if I ever get round to tuning might stick on the k14 I have
K14 lag a bit more, but they kick a lot harder
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Right I have been thinking. A few people on the forum are eunning vnts which is great. But from what I can see they are gearbox mounted. As much as I like to show off will they not fit down the back??
Maybe you want to read post 3 and 5 on this thread/ Wink
So apprently a few people have done such things. Any build threads soneone can point me toward then? Or a website that allows me to read up on turbo efficency flow size etc??
Mr Fish mounted his 22 frame vnt down the back on his 206.
Darren mounted a 20 frame vnt down the back of a 205.
It can/has been done, has less lag, etc. Main reason for gearbox mount is ease of adjustment/replacement and as you say, the bling factor.
S14 Zenki Build
[Image: IMAG0064_zps0e03c0d1.jpg]
GT2260 down back & Large frame lorry turbo
(20-08-2014, 01:02 PM)Dave Wrote: [Image: IMAG0064_zps0e03c0d1.jpg]
That's absolutely epic.
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
So got another turbo off a 205 lying about courtesy of pugmanxud. While my engines out AGIAN might put the one in due to non egr manifold. Anyone confirm that manis will fit and that the exhaust elbows the same? [Image: f73a7067fe7b9b2e97d7e72147524b10.jpg][Image: a37615302ea4c8f217a233d33a28189c.jpg][Image: 495530d96361cfeb58e0cc651fb74b45.jpg][Image: 6bf58ebb97fa2dbc36f68eceaac57f76.jpg]
The 205 it came off used to be mine so its a known good turbo aswell.
The second question of the night is ive been offered a t25 turbo off a nissan 300sx. Anygood or leave alone. Its only £20 if iq want it. Doing a big power build at start of year ready for april and insurance change over.
T25 on my old car was pretty good. Might not be a quick to spool as other turbo's, but anyone who has been in my car will know it felt quick.
Fair enough. I have a feeling though that the nissan ones dont fit well. Dont know why, just an inkling. When did it spool at?
T25/T2 hybrid I believe is possible?!
Ok may be something to look into. Easy fitment then. Just need to get hands on a t2 maybe.
Anyone on here played with hybrid t2? Still need confirmation on the mani. Because if they are the same could always bolt up a hybrid to this manifold later down the line
Mine fitted fine behind the engine and was off a Nissan 300zx.
Can't remember the full spool time.
300zx I meant not sx lol
Anyhelp with the k14 pics then?
  Talk exhaust.... blinkyeatu 20 5,064 24-08-2015, 08:42 PM
Last Post: 306pc
  Turbo talk Danny2009 6 1,860 16-08-2014, 05:01 PM
Last Post: ADV_93
  Turbo talk David 43 12,689 11-11-2012, 10:26 AM
Last Post: Ruan
Users browsing this thread: 21 Guest(s)
