05-04-2014, 11:42 AM
At Zachs and we've looked at my refurbed Bosch pump and the courier has done this to it !!! Can it still be fitted or has it had it???
f*ck !!! Shall I fit this pump?
05-04-2014, 11:46 AM
I am SOOOO not happy about this....
on phone to courier now Wishes for more power...
05-04-2014, 11:59 AM
should be ok, as long as the other three are done up tight. But you ideally need them all.
05-04-2014, 12:07 PM
(05-04-2014, 11:59 AM)Jonny81191 Wrote: should be ok, as long as the other three are done up tight. But you ideally need them all. What I was thinkin, I only run three, two at cambelt end, one at bottom corner Wishes for more power...
05-04-2014, 12:09 PM
(This post was last modified: 05-04-2014, 12:11 PM by Jonny81191.)
and you could wind the nut on, it'd hold it a bit
In fact, get a quote from a welder to fix it, bearing in mind it'd have to be stripped bare, then get the courier to pay it. Then take the money and fit it anyway Welding and fabrication projects undertaken, contact me for more information.
05-04-2014, 01:28 PM
Ive sent one with myhermes and they snapped the pulley, so I used a 24hr Yodel option this time.
Not happy Wishes for more power...
05-04-2014, 01:44 PM
Avoid yodel like the plague!
05-04-2014, 01:45 PM
Id weld that lug back on without striping the pump, just do it in stages
05-04-2014, 01:56 PM
Liquid metal it back, be reet..
05-04-2014, 03:46 PM
sheeeet! thatll be fine though as said. id use a bfo washer to grip the pump. but i am a pikey
05-04-2014, 03:56 PM
Big washer I'm sure it be ok, was it Hermes that post by? Had a box squashed to hell
05-04-2014, 11:16 PM
Couldn't believe how careless they are when I saw it. Hopefully you guys finish the job off tomorrow quick
Team disASTOR?
06-04-2014, 04:34 AM
%**<%€ %**><#> ^#>$$> ^+€>+>>. RANT OVER !
Piggy....would you be up for rebuilding my pump again if I can get another casing? Zach told me he'd fit it once you've rebuilt it the smokey old bus that sounds like a tractor...
06-04-2014, 07:28 AM
So not guna fit this one?
Is it not worth zach doing it to avoid stupid couriers again? Ive put in a claim with the courier....see what happens. Wonder if someone has a bare casing going cheap/for bear tokens??? Wishes for more power...
06-04-2014, 10:48 AM
I've got a f*cked Bosch depends how quick you need it?
Don't have much luck with posting pumps piggy :/
06-04-2014, 10:54 AM
No. I dont.
Its why I used a different courier this time!! Wishes for more power...
06-04-2014, 07:17 PM
i have a empty casing chap if u after 1
06-04-2014, 08:07 PM
(This post was last modified: 06-04-2014, 08:07 PM by devils_fuel.)
Thanks chaps, how much chaps?
06-04-2014, 08:30 PM
Ozone said he may have one mate...worth checking with him first...esp as he has the original
06-04-2014, 08:43 PM
£15 posted
06-04-2014, 10:16 PM
(06-04-2014, 08:30 PM)Piggy Wrote: Ozone said he may have one mate...worth checking with him first...esp as he has the original Good call, pm sent (06-04-2014, 08:43 PM)Teddy Wrote: £15 posted Thanks mate, hopefully I'm sorted but if not I'll pm you the smokey old bus that sounds like a tractor...
08-04-2014, 12:26 PM
Seriously, it'll be fine, just make sure all the others are done up, that end of the pump locates into the pump bracket anyway due to the register on the nose, as long as you've got two on you'll be fine.
I wouldn't say it's worth the hassle of stripping and rebuilding the pump, unless you intend to reseal and put new vanes in.
08-04-2014, 12:40 PM
Err, am I the only one thinking it should of been packaged better..
08-04-2014, 02:43 PM
(08-04-2014, 12:40 PM)silverzx Wrote: Err, am I the only one thinking it should of been packaged better.. Other than wrapping it in a duvet, not sure how much more packaging I could have used Wishes for more power...
08-04-2014, 02:45 PM
(08-04-2014, 12:26 PM)Ruan Wrote: Seriously, it'll be fine, just make sure all the others are done up, that end of the pump locates into the pump bracket anyway due to the register on the nose, as long as you've got two on you'll be fine. this pump was refurbed for me hence i am really p*ssed! Zach said its not worth fitting as its the cam side top one which is most movement from the pump happens + there isnt anythning for the stud to remotely grip to I may just get it reshelled (08-04-2014, 12:40 PM)silverzx Wrote: Err, am I the only one thinking it should of been packaged better.. it was very well wrapped mate the smokey old bus that sounds like a tractor...
08-04-2014, 02:46 PM
Tbh, if Ruan says its ok, its ok.
He had I'm sure fitted more of these than I have had hot dinners Wishes for more power...
08-04-2014, 02:52 PM
I wouldn't put that pump back on the car.
I once ran mine on three bolts (couldn't be ar5ed to tighten the bottom front one up) and it ended up coming loose, the other two studs snapped, the taper bolt went on holiday and the pump was held in place by the pipes. The mounting bracket also ended up being changed as the hole had elongated into an oval. Don't do it wrong, do it right and do it once. |
