19-03-2014, 04:57 PM
cool when did you do that welspug?
Cleaning rusty parts with Electrolysis
19-03-2014, 04:58 PM
19-03-2014, 05:16 PM
I did that last year at some point, some 205 Driving lamp surrounds came up very well, also my 205's original springs came up well enough for me to find the two yellow paint marks, which I doubt I would have done had I just gone at them with a grinder really!
I do intend to have another crack as I have plenty of rusty lumps of Peugeot ![]() Doesn't hurt the seals one bit, its just a soap solution.
19-03-2014, 05:38 PM
(19-03-2014, 04:58 PM)cully Wrote:(19-03-2014, 04:47 PM)Piggy Wrote: Is something like a caliper going to be ok though...would it not ruin the seals? Pretty buggered... But thats limescale!! Just know that soda crystals are pretty fierce...and if they take rust off, that kinda would concern me regarding seals. But if its fine, then thats ace. Will be mocking one up asap!! Wishes for more power...
19-03-2014, 05:49 PM
the crystals arnt taking the rust off though!
its the action of electrolisis releasing hydrogen/oxygen bubbles from the metal serface that removes the rust not the crystals the crystals are only used to make the water conductive so the electrons can pass from positive plate to negative plate
19-03-2014, 07:39 PM
Wow that is amazing. I need a bucket!
20-03-2014, 12:15 AM
Great job, think I'll have a go at this some day.
20-03-2014, 02:20 AM
That's amazing! I might have to do this with various parts of my pug! And motorbikes!
20-03-2014, 02:42 AM
Well done cully a man of much useful knowledge
20-03-2014, 06:18 PM
to finish off
here's the last part sceince part3 now the parts are semi clean bearings and the ABS sensors were removed the ABS sensor came out without destroying it, it is in one piece! ![]() the last bit was to go over the hub with a drill with a wire brush attachment, flushed it off with brake cleaner, quick wipe dry with a cloth mask up then give it a coat of primer to stop them rusting again till i decide on colour ![]() ![]() good as new just needs bearings pressing in
20-03-2014, 09:56 PM
You'll have the cleanest hub on any 306 anywhere in the world...
20-03-2014, 10:37 PM
That's not true. My hubs looked like that. 20 years ago
21-03-2014, 02:25 AM
Bilthamber Deox C the 1kg will fill a wheelie bin think of the parts you could do with that!
Perv 306 1.6 5 Door Hore - Sold 110bhp 207 Hdi Sport - Used as a Brake 173bhp T25 Ph1 Diablo Dturbo - Scrapped Thirsty Bitch Volvo 850 Estate - Sold 51bhp Berlingo Nad DT Van - Sold Slow as f*ck Dispatch Work Horse www.prestige-auto-care.co.uk
21-03-2014, 06:32 AM
We do copper plating in school by using copper sulphate solution, although having a anode (+ive terminal) made of copper should have the same effect!
Very cool stuff!
21-03-2014, 10:58 AM
Quote:good as new just needs bearings pressing in At which point half the paint will get scratched back off heh. Looks good though, have seen this done before with big agricultural stuff, they have a massive dip bin at CFM down here, didnt realise it had such quick effects though, pretty epic, might have to rig one up and try it out myself some time! | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]()
21-03-2014, 01:16 PM
when the bearings are pressed in the centre hub will hide the press marks
![]() im now eyeing up if my old bottom arms will fit the tank ![]()
25-03-2014, 10:33 AM
ok with the great sucsess of the hubs i thought id go for something bigger as another experiment
![]() que the rusty spare wheel! ![]() so ive used the same idea as before but this time i have made a tank out of roll cage sides lined it with plastic sheet and filled it with water ![]() ![]() ive guessed the soda this time ive added 1.5kg mixed it in, sunk the wheel and positive plate connected it up to the battery charger now its a waiting game to see the results ![]()
25-03-2014, 10:57 AM
Awesome box Cully.
I'm a keen one on using this method. I've got a wheelie bin which is better recycling old car parts than it ever was doing bits of cardboard (which can be burnt). Honda hubs are a bit longer as they are dual wishbone not strut so needed the room. I lined it with a steel repair panel which needs the occasional clean down to keep the process running well. Take siezed brake calipers for example. Just chuck the whole bloody lot in, caliper and carrier. Be sure to link the carrier to the caliper electrically. But leave it in for a short while and it'll no longer be siezed ![]() Can reclaim all sorts of stuff with this method. Just be sure to brush all the black stuff off before paint and you're laughing.
25-03-2014, 11:18 AM
That's mint
25-03-2014, 12:43 PM
Cant't wait to see that wheel and its results...
Try a beam next maybe? ![]() Wishes for more power...
25-03-2014, 01:58 PM
![]() What effect does this process have on the rubber? I presume none? ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
25-03-2014, 02:28 PM
(25-03-2014, 01:58 PM)Grant Wrote: Gets wet but that should be all. ![]()
25-03-2014, 02:39 PM
Wow definitely need to do this to my spare wheel over summer!
Just need a power supply...
25-03-2014, 02:52 PM
(25-03-2014, 02:28 PM)PE02KHG Wrote:(25-03-2014, 01:58 PM)Grant Wrote: Even better than that. I've had some rubber (like for example on brake calipers) where the metal has rusted on to it. So you can sit there trying to pick off the rust flakes which have become one with the rubber. This cleans it right off. Also when it's just rubbers, I'll stick them in a bottle of vinegar. Vinegar works well for derusting too, but electrolysis is the daddy. So much faster and self agitating where as vinegar needs the odd helping hand. But for just doing rubbers where there is no chance of an electric connection, it's the better choice.
25-03-2014, 04:37 PM
can't wait to see the result of that wheel
25-03-2014, 06:42 PM
Great work cully can't wait to see the result
![]() Astor 6 Fast road/track project
25-03-2014, 08:11 PM
25-03-2014, 08:49 PM
theres a guy over on the AX owners club that does this for his rebuilds, then zinc plates the parts, looks awesome, and the zinc kit it cheap on ebay
Project: Formula Peugeot
