knocking noise
Got a knocking noise coming from the front nearside area when im accelerating also freewheeling, am i right in thinking it is a cv joint ?
More likely to be a ball joint I would think.
Edit,
or P bush
(22-02-2014, 07:13 PM)DeeTurbo Wrote: More likely to be a ball joint I would think.
Edit,
or P bush
I like the sound of that rather than a cv joint ill have a proper look tomorrow its just started tonight
Had the same thing, turned out to be driveshaft
I have the same kinda thing, usually under hard accelerating/braking but it does sometimes happen over potholes etc but I do know from having it out before, that driveshaft definately needs changing so I'm trying that first Smile
Does it knock on braking too. Have someone look when you brake and see if the wheel moves back in the arch. If so id change the wishbone and balljoint with it Smile
Team disASTOR? Itwasntme
  Annoying Knocking / Scraping Noise mspdan 7 4,478 31-03-2014, 07:35 PM
Last Post: mspdan
Sad Annoying knocking noise Bnmtuning 7 4,365 01-03-2014, 04:53 PM
Last Post: Razorback_Rob
