Annoying knocking noise
Sad
Got a really annoying knocking noise seems to be coming from left side front & rear of the car, only when going over small bumps & potholes especially!! Sounds like the parcel shelf is having a fit.
My enitial thinking is that it's something to do with suspension, but could really narrow this down.
Also, the rear of my car sounds like a squeeky door when I get in or out, I think the rear axle is on it's way out I'm trying to source a cheap enough replacement!
Any thoughts
Cheers, mike
Anti roll bar drop links are a common source of knocking and are cheap and easy to replace
If the beam is on its way out that can knock when it gets bad enough.
Droplinks would certainly be my first port of call though as 306's seem to be pretty hard on them and cheap pattern ones can be dead in just a few months.
dont buy cheep drop links or youll be doing them again 6 mths later!!!!
Drop link or beam mounts
Cheers lads i reckon il change the drop links first not for the cheap ones!!
bought lemforder ones yesterday and fitted them, great difference straight away. To be expected really since my ones were done.
I've got what sounds like the same problem on my drivers front but drop links feel tight. Gonna try new drop links anyway as they're cheap enough.
Team disASTOR? Itwasntme
  Annoying noise...lift pump? doogle-d turbo 12 5,989 24-06-2014, 04:55 PM
Last Post: Mattinthehat
  Annoying Knocking / Scraping Noise mspdan 7 4,461 31-03-2014, 07:35 PM
Last Post: mspdan
  knocking noise Scouse282 5 3,397 01-03-2014, 05:00 PM
Last Post: Razorback_Rob
