11mm problems
Wondering if anyone can help?
At Danny's swapping pumps , we have just got it running but it's running like shit.
It sounds almost as though the timing is out , but we have checked timing 2 times now and it's been perfect. Won't rev properly and chucking out white smoke...
The pump didn't have any diesel in it at all when sent?
If anyone could help asap then that would be brilliant
Cam plate 180 degrees out ?
Used Lewis's old injectors off his 9mm so that's not a issue
Tried advancing and retarding, makes no differance to the running
Team Doesn't own a 306
Ignore that
Who built the pump on first place?
www.prestige-auto-care.co.uk
I'm not really sure , it's from strictly_derv on here and I do believe it was on his 205
did you romove the belt or leave the pulley in place when changing the pump
how did you put the belt on as it is easy to put the belt on a tooth out
306 XUD9 gt2052s
306 hdi stage 2 (hdi tuning)
205 STDT -new project
I did the belt mate it was timed spot on I've done 4 belts alone on Lewis car
Put the 9mm back on as he needed the car for work
Fired straight up and ran perfect
My diagnosis is the pumps f*cked!
Did you open the pump to see how it was put together?
(07-01-2014, 12:14 PM)Danny2009 Wrote: I did the belt mate it was timed spot on I've done 4 belts alone on Lewis car
Oh dear! I no you locked it off but did you try knocking pump a tooth out? Remember Ted having issue like this and sure he knocked it a tooth out and it was ok after that, if I remember right anyway.
If he wants it stripping and checking let me know. Got Chris's to build yet
Should never require the belt slipping... Some thing is seriously up if you have to...
(07-01-2014, 03:04 PM)Ruan Wrote: Should never require the belt slipping... Some thing is seriously up if you have to...
Didn't you have to run your pump fully advanced on the nanstone? Due to having diesel knock if it wasn't? Did you ever sort that? (ignore if I'm talking crap & and sorry for thread hijack)
I was going to take the top off and have a look see what the internals look like, it took Lewis 4 weeks to recieve and had a pipe on the inlet going to the outlet guessing so no diesel leaked?, but there was no diesel in it
Didn't want to take it to bits until Lewis spoke to the seller don't want them turning round saying it was fine and I must have done something to it bla bla
The pump came straight off a running daily driver, I can't be ducked surely?
I did not build the pump, but I've had it on 2 cars without any issues. Feel free to PM me.
Regards to the dispatch I received full payement on the 18th as the money I received took the PayPal charges, I sent it on the 29th I believe, to be delivered for Thursday 2nd on Jan. late dispatch I know but I had apologised for that.
Stage 2 XUD Sedan
Vane pump could be seized, doubt it was off sat around for long enough though.
It was off the car for 2 weeks, fuel was never drained, as said pipes where blocked off and this was done straight away, but the fuel must have slowly drained through the delivery valves.
Stage 2 XUD Sedan
doubt it would of packed up that quickly i had one in a cardboard box for months with no fuel in and worked fine
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
Well it's definatley not working now
Had to put the 9mm back on in the end and it runs fine again
Was advised to give it it's own fuel supply out of a clean container with fuel in, it didn't want to pull its own fuel through was spluttering but wouldn't start
Sounds like vane pump, was it struggling to rev as well? Like the max throttle screw was to far out almost?
Yea clattered like f*ck and engine started shaking like mad when reved
So it drew enough to be bled then? If it was vane pump then it wouldn't draw at all.
I can't understand how it would work on a car then not work on another car.
Other forum members can vouch this is a working pump which had been on the car fully working up till it was removed when the car was scrapped.
It still sounds like timing to me
Stage 2 XUD Sedan
It's nothing to do with belt timing had the belt on and off twice to check
It Dosent draw it's own fuel or it would draw it out of a container
It needs lots of help from the grenade and throttle and when it does run it runs like shit
i had a problem with my 11mm pump knocked liked f*cked and loads off white smoke it matched up to tdc so ran it a tooth out on pump and was fine after that all problems went
http://www.youtube.com/watch?v=nLJR0HQKP24
That was pretty much what mine was running like last night^^^^ ,
Loads of knock , lumpy running and lots of white smoke.
Really dissapointed to be honest but what can I do?
Changing the timing wont make it suck its own fuel though surely? Did it run better as you pumped the grenade?
Didn't really run much better with pumping the grenade no , still ran like utter shite
It's was timing on mine was to advanced not firing right
Didn't really try pumping the grenade when it was running shouldn't need to really
Wierd how it won't start out of a can my 11mm did ........
Mine needed a lot of advance to make it perform OK - but then it had a turbo that only came on song past ~3200rpm... So needed a lot to help, and also that belt has been used many times - it's probably a bit stretched!!
But yeah, sounds like siezed vane pump to me sadly Sad
  bosch 11mm hybrid pump problems ash gibbo 8 7,156 18-07-2012, 07:51 PM
Last Post: ash gibbo
  11mm problems.. Seb_Ryan 8 4,782 20-02-2012, 01:17 PM
Last Post: londondan86
Users browsing this thread: 25 Guest(s)
