Silverzx's White 205 1.9 DT XUD
Get a new light stalk, they always wear out on 205
Just follow the wires from the original cluster to underneath the glovebox (which you dont have lol) and literally unplug 2 plugs its very simple
Current cars
Subaru Impreza 2.0d - Daily
(12-12-2013, 11:58 AM)td_dan Wrote: Just follow the wires from the original cluster to underneath the glovebox (which you dont have lol) and literally unplug 2 plugs its very simple
Really that simple? If it is I'm onto a winner winner chicken dinner time!
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Ye just trace the wires and plug it in i think its 2 plugs into the main board
Current cars
Had a brief glance at the wiring and didn't like what I saw!
Finally fixed the speedometer by replacing the cable so can finally see how fast I'm actually going again.
Still have a nice boost leak (I think) as it's running 15 psi, a random drop from 18. It sounds like it's pushing a lot of air and not going anywhere.
My main beam has decided to randomly decide when it wants to work that wasn't particularly fun this evening. Think I need a stalk or possibly new HIDs as they work on sidelight (not main or full). Perhaps the cold doesn't agree with them.
Also need a few other 205 bits if anyone's breaking one..
[Image: ehepa5yg.jpg]
S14 Zenki Build
What bits do you need mate?
I need a blower motor Wink silver boy take your stalk apart and see if you can sort it, I done it on mine when my washers were dodgy!
(18-12-2013, 06:15 AM)Paul_13 Wrote: What bits do you need mate?
PM'd.
(18-12-2013, 09:10 AM)Tom Wrote: I need a blower motor Wink silver boy take your stalk apart and see if you can sort it, I done it on mine when my washers were dodgy!
Uhhhh, how..? Big Grin
S14 Zenki Build
Take it off, 2 screws on the bottom then, take the metal clips off holding the 2 halves together and see what's on inside.
(18-12-2013, 09:24 AM)Tom Wrote: Take it off, 2 screws on the bottom then, take the metal clips off holding the 2 halves together and see what's on inside.
Probably a lot of corrosion.
Shove a load of foil in there? Blush
S14 Zenki Build
Mine was just covered in dirty grease, cleaned it all out and stuck some fresh in there and its fine now.
(18-12-2013, 09:48 AM)Tom Wrote: Mine was just covered in dirty grease, cleaned it all out and stuck some fresh in there and its fine now.
Grease you say..
White grease any good?
S14 Zenki Build
Slippery grease mate Wink I just use multi purpose grease for everything lol I'm sure Vaseline would work fine as well.
don't worry trent il be over one day soon. it will be bosched!
(21-12-2013, 09:10 PM)ozonehostile Wrote: don't worry trent il be over one day soon. it will be bosched!
Thanks dude!
Alternator died, drove home with no electrics under the drawing night sky.
Sub went first, then radio, then lights, then indicators.
A job for tomorrow.
S14 Zenki Build
Check the pumps not leaking, alternators don't like oil and that. Don't want you killing another one.
(29-12-2013, 09:31 PM)Paul_13 Wrote: Check the pumps not leaking, alternators don't like oil and that. Don't want you killing another one.
Just replied to you over on 205gti.
Hopefully it's getting bosch put on soon so shouldn't be a problem either way.
When it was fitted I accidentally put the + and - on the wrong way and it smoked a bit so think it's done well to last this long to be honest!
S14 Zenki Build
Haha, at least you know what killed it though
11mm's on as of Sunday morning, much thanks to Darren for the pump and Zakk for the much needed assistance fitting it! A massive improvement over the lucas.
Lucas before:
[Image: IMG_3565_zps11efac0e.jpg]
Bosch after:
[Image: IMG_3571_zps18fd0e99.jpg]
At the Exeter meet:
[Image: IMG_3579_zps10725856.jpg]
[Image: IMG_3575_zpsd6e15d8b.jpg]
S14 Zenki Build
How the fcuk did you manage that?!
ahh bugger, doesn't look like that tickled :S
Was a good refresher fitting the bosch, it's been a while haha.
Had a bit of an issue with the tensioner on the cambelt being a bit reluctant to move up or down and the issues with the oil breather hose on the rocker cover. Apart from that it was a nice job :-)
Oh and it ran like shit on first start, moment of inspiration, advanced the pump a few degrees and instantly ran perfectly haha
So gay about hitting the front, especially after all the careful hammerite application the night before :-P
Only picture I took
[Image: 20140105_095819_RichtoneHDR_zpsd00vx9db.jpg]
It goes well at 25PSI on 11mm & TD04!
S14 Zenki Build
iv got a white gti front valance mate but would need collecting from birmingham
Current cars
(07-01-2014, 10:04 PM)td_dan Wrote: iv got a white gti front valance mate but would need collecting from birmingham
Thanks dude, PM'd you as you know!
On another note I put brand new Bosch Duraterms in this bad boy when we fitted the 11mm and it hasn't cured my smokey start up issue.
I'm a bit stumped why it still starts rough as bugger!
S14 Zenki Build
I've got a genuine white Dturbo valance sat in the garage along with matching rear if your interested
Stage 2 XUD Sedan
So tempted to break the damn thing.
Anyway....
S14 Zenki Build
that wing! you sure you couldn't of hammered it in a bit??
(09-01-2014, 04:56 PM)mr_fish Wrote: that wing! you sure you couldn't of hammered it in a bit??
Don't see the point, it'll only crease in the opposite way and it's better poking out then in if you ask me.
Had a quick look at what it could potentially be worth and have a few bits...
As a rough idea to what I could recoup from the car and my XUD stock pile:
ARP XUD Head Studs £200
GT2052V £80
K14 Bolt On £40
TD04L Bolt On £150
306 FMIC Kit Bolt On £150
Stack EGT Gauge, Probe & Adapter £40
Stack 35 PSI Boost Gauge £30
11mm Rebuilt Lobb Pump, lines, injectors £150
Aftermarket backbox £25
2.5" steel bends, straight & various bits £50
205 STDT Clocks & Loom £40
XUD Cambelt Kit £30
Bosch Duraterm glow plugs £15
9mm Bosch Pump, lines, injectors £80
Non-EGR inlet x 2 £20 each
7 x 205 GTi Speedlines £150
205 STDT exhaust £15
XUD engine x 2 £50 each
Scrap value for 205 & 306 shells £80 each
and various other random bits.
Could probably get a grand back if I tried and start over or just drive my Datsun.
Someone find me a wing, bumper and headlight in their local scrappys pretty please!!
S14 Zenki Build
I'll have clocks and loom, td04 and pump if you break!
Oh and boost gauge
My mate will most likely have the head studs
Ryans got a GTi shell on his drive he needs rid of by the way
