Joey the VNT boosted 205!
Lots of movement with this coming up soon! hooray Smile Just a little teaser...
[Image: IMG_20131118_150559_zps6cada282.jpg]
Are you running a billet one at the moment then?
I got a standard rubber one in the bottom and apparently a solid fork bush. So this should tighten it up nicely Wink
It will be horrific with the solid fork bush.
I had billet in both, on my XSI and i hated it. The mrs loved it however lol
Both is too much IMO. I could only make an un-educated guess as to what it would be like on a derv. But at a stab, worse than a perf?
Probably worse then! Im even more excited now aha!
Back to losing water at a much more reasonable rate!
A rad looks exactly how you imagine but I took pictures of the nifty slimline fitting kit :p
[Image: IMG_20131119_154135_zpsad1ebd1c.jpg]
[Image: IMG_20131119_154148_zps696882ff.jpg]
U never used those fitting kits? There awesome
[Image: av5ym8.jpg]
Yeah used one once before but they're awesome!
Usually use cable ties myself.. For everything..
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
I do keep a pack in the car just in case Wink
I think that exhaust looks good Smile
Sounds good to Smile thanks bud x
[Image: IMG_20131120_150959_zpse8b902ce.jpg]
This weird little thing broke of yesterday whilst changing the rad. Apparently its some kind of earth point. Commonly break on the 205's so I just cut it off and put ring terminals on there and covered them in grease, all sorted now.
Right did something stupid today... and i washed the car.
[Image: IMG_20131121_152250_zpsac446f28.jpg]
Wait for it...
[Image: IMG_20131121_152301_zps6f978605.jpg]
[Image: IMG_20131121_152308_zps2e4f65d6.jpg]
Yep inside the car. Dont worry its only temporary til i get a longer length of fuel hose. But i got impatient.
Also have a transit pump on the way for making awesomeness.
Epic! lol wonder if it will make much difference with veg oil going though the car not under it.
You can see why the car doesnt like it, i have been driving for about 45minutes before i put that pipe in and i fired it up and the pipe went proper cold with the fuel going through it :/
Notice a difference with the fuel banjo ;P
I found it made a massive difference on mine
I'm going for a drive this evening, hoping for some 3rd gear wheelspin aha Wink
What have you done along the lines with the primer and the fuel filter? As they are still at stock diameter.
Stage 2 XUD Sedan
I dont have a primer nor a fuel filter... Im just having some fun atm. Like i said i got impatient and just stuck it on! I have a primer on the way, but fuel filter im a but stuck with, trying to find a landy fuel filter housing (for a reasonable price) that i can mount either in the bay or under the car with a big spin on filter.
Ah fair one. Be careful running it de filtered! The cars 22 years old and that tank isn't going to be clean!
Stage 2 XUD Sedan
Im running mostly unused or 1micron filtered veg atm so not overly worried about it, i had a check over the strainer aswell before i done it and that was clean as a whistle and alot finer than the one in a 306!
And i guess if the pump does die i'll have to repair it from bits of this transit one i have here... ninja
Why don't you go for the filteriI've got?
(21-11-2013, 06:52 PM)Paul_13 Wrote: Why don't you go for the filteriI've got?
Because i read the small print and it says its 120micron and IMO its not worth having. Most oem filters are around 5 micron. Like i said above i filter my veg down to 1 micron cold, so 120 is about enough to catch chips with lol!
Just get a TT filter on it? Only like £5 if that saves killing pump?
Already got a TT filter. Not big enough.
Wake up Chris Wink
Also forgot to add, i just got home from the test drive. And its pretty awesome i must admit. I have been driving with a blocked fuel filter for weeks so all this power feels so new to me lol. Its like i've awoken some kind of beast.
lol I must have missed that bit whys it not big enough? Suppose at 1 micron doubt you will run in to, to much trouble any way.
The in/out pipes on the filter aren't 10mm :p
(22-11-2013, 07:37 AM)Tom Wrote: The in/out pipes on the filter aren't 10mm :p
Oooooo I see Wink
If you do find a large filter, be sure to order me one / share the love. Wink
S14 Zenki Build
Thumbs Up Project "KEV"....boosted Mini Piggy 59 39,661 24-04-2018, 12:58 PM
Last Post: Magenta Sunset
  The boosted 205 rat - pictures and video added (25.09.16) ginge191 134 112,072 21-04-2017, 10:46 AM
Last Post: ginge191
Users browsing this thread: 19 Guest(s)
