03-11-2013, 11:06 AM
So is it going back with a standard crank or 2.1/2.2 diesel ones for some extra capacity?
Cully's spare Gti6 engine
03-11-2013, 01:22 PM
Cully will you be replacing the core plugs? I did mine as a precaution and all were ok except one for some reason. For the sake of £1 each, its worth it so it doesn't piss coolant all down your engine bay a few months after you fit it lol
03-11-2013, 01:53 PM
(03-11-2013, 11:06 AM)Dum-Dum Wrote: So is it going back with a standard crank or 2.1/2.2 diesel ones for some extra capacity? havnt thought on it ..... (03-11-2013, 01:22 PM)Niall Wrote: Cully will you be replacing the core plugs? I did mine as a precaution and all were ok except one for some reason. For the sake of £1 each, its worth it so it doesn't piss coolant all down your engine bay a few months after you fit it lol nope theey cleened up ok so am going to give them a mis tempted to get the crank n rods ballanced though
03-11-2013, 01:55 PM
Mine looked ok on the outside but one wasn't on the inside. Will see if i still have it for a photo.
03-11-2013, 02:37 PM
(03-11-2013, 02:37 PM)Dum-Dum Wrote:(03-11-2013, 01:53 PM)cully Wrote:(03-11-2013, 11:06 AM)Dum-Dum Wrote: So is it going back with a standard crank or 2.1/2.2 diesel ones for some extra capacity? ???? whats the throw on a 2.2 crank? the 6 is 86mm x 86mm a square engine thats why it wants to rev i dont see how changing the stroke increases the capacity on a 6 engine without addig extra block hight,surely boreing the block would ad extra capacity DW12 is 85.00 x 96.00 s16 uses the same rods as the 6 from what i can see
03-11-2013, 04:54 PM
(03-11-2013, 03:33 PM)cully Wrote: Whats the throw on a 2.2 crank? As you've seen the throw is 96mm, an extra 10mm. The GTi6 rods are 158mm center to center and the S16/Mi16 are 152mm center to center giving you the 5mm difference you need. The small end on both is 22mm and the big ends are both 53.7mm
04-11-2013, 10:54 PM
just had an email for my bearing supplyer
good prices! Glyco main bearings H1057/5 £23.50 big end bearings 01-4298/4 £18.00 thrust washer A188/4 £9.95 ACL Duraglide main bearings 5M1677 £30.25 Race series big end bearings 4B7700H £70.50 Piston Rings there are two types 1.5/1.5/3.0 which would be £64.95 1.5/1.75/3.0 £55.00 Shipping would be £8.50 All prices are inc vat
04-11-2013, 11:26 PM
Not bad. you going to fit the rings your self?
04-11-2013, 11:31 PM
04-11-2013, 11:41 PM
Oh thats a fun game!
06-11-2013, 10:31 PM
took the old piston rings off no problems!
measured them and they are 1.5/1.5/3mm decided to check the big end bearings with a micrometer could only get an imperial one so had to convert the reading! the micrometer is a 1" to 2" size so the reading is 1.9...50+18 = 1.968" which works out to 49.987mm =standard bearings
08-11-2013, 11:19 AM
Have ordered my main bearings, big end, thrust washers and ring sets
Paypal account looks real sad now ![]() have been going mad at cleaning stuff the box of clean is getting bigger have also painted the Block Red! Mmmmmmm
08-11-2013, 12:59 PM
Think I have to stop off on the way home sunday
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
08-11-2013, 09:54 PM
S16 used the same block and crank, however a 152mm conrod with taller pistons, bushed small end and circlip located gudgeon pin, a rather heavy piston but usefully meaty valve cutouts.
gti6 uses 158mm conrods and a shrink fit gudgeon pin, and rather poor valve cutouts and thin piston crowns, a whole 1mm can be added however, to allow for cams like PT81's to be timed up correctly and safely, without this, and a thicker gasket if the head has been skimmed, I wouldn't even think about changing the cams.
12-11-2013, 09:08 PM
peugeot phoned the head gasket was in so have picked that up,
also the bottom end ACL bearings ,rings and thrusts are in so will pick them up tommorow
14-11-2013, 06:12 PM
now have all the bearings, headgasket,seals in my hot sticky hands
so soon will be building ![]()
15-11-2013, 05:18 PM
collecting info on torque settings
info as a PDF
torques.pdf (Size: 102.74 KB / Downloads: 210)
some of the torque settings are followed by an angle so i made myself a protractor to fit over the 1/2 torque wrench use a fixed point on the block and turn the wrench the number of degrees required
15-11-2013, 06:25 PM
I bought an angle gauge instead.
15-11-2013, 06:42 PM
Yeah Cully mine was £4 from Amazon. Hardly breaking the bank you tight northerner....oh hold on!
Ill bring mine down on Sunday if you like? Hoping i won't need it for a while!
15-11-2013, 06:45 PM
Ive got one of the angle things, but never used it...i just do it in steps of 90, its not exactly hard to follow 90 degrees, simply start, pick your finish point at right angles and follow to it, then add a 45 / 90 as required.
Looking good though, nothing like a proper engine rebuild
| #DervMafia | ![]()
15-11-2013, 06:48 PM
(15-11-2013, 06:45 PM)darrenjlobb Wrote: Looking good though, nothing like a proper engine rebuild This! Ive actually found it really satisfying building mine up and turning it all over and it all works! Just need to get it running now
16-11-2013, 06:33 PM
(15-11-2013, 06:45 PM)darrenjlobb Wrote: Ive got one of the angle things, but never used it...i just do it in steps of 90, its not exactly hard to follow 90 degrees, simply start, pick your finish point at right angles and follow to it, then add a 45 / 90 as required. This is what we did in the garage as all engines are torqued down when built-can't see pug farting around with angles etc when building them ![]() the smokey old bus that sounds like a tractor...
started rebuilding this today as the weathers been pants so havn't been able to work on the car so its in the garage today!
cleaned crank ready for instal new ACL bearings and thrusts installed pre assembly lub main caps fitted bearings with assembly lub main caps being installed and torqued down after each cap is installed the crank is turned to see if its free of pinched tight all main caps installed and torqued down crank was still nice and free starting to install the pistons and ACL Race big ends all in windage platew oil pump in oil pump drive and chain oil bath as it stands tonight
06-12-2013, 01:18 PM
that would have meant £1200 on pistons and rods...
I put ACLs in mine when we built it, also went for a set of ARP rod bolts too... Maybe something to think about?
JP
| Cully's Bianca 6 R150 YVM | cully | 994 | 859,301 |
13-01-2019, 04:04 PM Last Post: cully |
| cully's XU10J4RS | cully | 11 | 10,287 |
30-06-2016, 12:53 PM Last Post: welshpug |
| Cully's Electric car ..T project | cully | 144 | 98,191 |
16-04-2016, 04:14 PM Last Post: cully |
