Threads: 591
54
nah quite compact...its exhaust manifolds and getting downpipes to fit which could be a pain.
I foresee the exhaust tunnel will need some 'work'
Threads: 169
91
Given 1 thank(s) in 1 post(s)
The 'exhaust' tunnel would become a transmission tunnel, and the exhausts would consequentially be run to each side of the car, one for each bank.
Threads: 591
54
ah yeah that makes sense.
less chassis work
Threads: 169
91
Yep, less chassis work, more bwarp
Threads: 102
9
(24-10-2013, 06:32 PM)lolsteve Wrote: How about a kv6 engine? Might find it easier to fit in the front
nooo, he doesn't want any K series stuff in the 306, plus that engine is quite expensive to fix.
anyway grant, the cars looking good, id have moved the spare wheel further into the boot, also binned the standard dash and made a full blown custom one up. like what's in the caterham 7
have you thinned out the car loom and fitted a removerable boss?
Threads: 541
124
Just a thought but wouldn't it be easier to buy the RV8 engined 306 that keeps popping upon ebay and transfer the space frame and that sort of stuff across
Edit; thread here http://306oc.co.uk/forum/thread-5895.htm...nted+rover
Further Edit; or this one http://www.ebay.co.uk/itm/peugeot-306-v8...7675.l2557
Threads: 91
83
Audi 2.7T V6 or 4.2 V8 - or name the engine and make an adapter plate (though for me, 3.0 or 4.0 V8 CR TDi)
Mid mounted on an Audi 01E FWD transaxle
318is rear subframe
Custom propshaft
Bonza.
Though IMHO - no point in having a RWD 306 - the wheelbase is just TOO short, you're not going to be able to drift it... So you may as well do a 4x setup - in which case still use the 01E tranny but shove the engine up front, but have a Quattro one with the Torsen centre diff and then just link it up again to your 3 series or RX8 rear subframe.
Threads: 169
91
(24-10-2013, 11:27 PM)procta Wrote: (24-10-2013, 06:32 PM)lolsteve Wrote: How about a kv6 engine? Might find it easier to fit in the front
Definitely don't want anything K series!!! Avoiding that like the plague lol
The spare wheel is currently on the car, so nowhere in the back, and a fuel cell is getting welded into the floor at some point, so the wheel goes wherever there is space. I'd love to make a custom dash, but when the cage/frame is in, there most probably won't be one at all. Being a short fucker I have no need what-so-ever for a removable wheel, and it will only move the wheel further away from the stalks. The loom will be cut down when i remove the dash
(25-10-2013, 07:39 AM)Dum-Dum Wrote: Just a thought but wouldn't it be easier to buy the RV8 engined 306 that keeps popping upon ebay and transfer the space frame and that sort of stuff across
Good call Chris, none of the pics work  but i Think I can remember it. Seems a little pricey though?
(25-10-2013, 08:38 AM)Ruan Wrote: Audi 2.7T V6 or 4.2 V8 - or name the engine and make an adapter plate (though for me, 3.0 or 4.0 V8 CR TDi)
318is rear subframe
Custom propshaft
Bonza.
Not really after a diesel though dude. The whole point of this is for maybe a little more power, but just doing something that hasn't been done, fully, and for epic noise.
With regards to drifting: It's not what I'm building this for lol
I want to keep some aspect of the 306 handling so thats why the alfa box would be great for the weight distribution.
Besides, the new fiesta is shorter than the 306 by 80mm, and Ken Bloc manages just fine
Threads: 91
83
Ken Block's fiesta is 4x  And both of the first engines are pervs!
IMHO If you're going for handling - then put the engine in the middle of the car surely?! You can get away with short wheelbases with mid engined cars, but shoving the weight outwards is only ever a bad thing...
That's just my opinion of it... If you're trying to easily fit a V8 - up front, any RWD tranny... If you're trying to make one drive OK - Mid engine, Transaxle...
Other engine you might be able to get hold of on the cheap is an early Jaguar AJ-V8... Basically the replacement for the Rover V8...
Threads: 169
91
Trying to get the engine behind the seats, then a tranny box to the rear wheels will just work out too short. I agree, in an ideal world, that would be the best thing to go for.
Front engine, RWD, as i *think* even rear engined would work out with no enough space, as I would be trying to mount a Longitudinal engine transversely. Once the gearbox is mounted it would be about 3ft outside the car
The Jag V8's from what I see, tend to come up at about the £1k mark no?
Threads: 91
83
(25-10-2013, 09:25 AM)Grant Wrote: Trying to get the engine behind the seats, then a tranny box to the rear wheels will just work out too short. I agree, in an ideal world, that would be the best thing to go for.
That's why I say transaxle
Keeps it super, super short
Shafts literally come out STRAIGHT behind the bell housing.
Threads: 28
1
25-10-2013, 11:44 AM
(This post was last modified: 25-10-2013, 11:47 AM by floz123.)
Some good ideas here grant  did think once about putting a v8 in mine. Got it all planned out etc. Also considered a twin engine 1.8 turbo project. Have you thought of the 1uz v8? All aluminium and nearly 300hp standard
Also short wheelbase can drift...just not that well  look at the KP starlets...short wheel base and practically started drifting. It would be awesome either way..whatever you decide. All about having a different idea and making it happen
Threads: 541
124
Have you not got a V8 in this yet?
Threads: 581
195
(25-10-2013, 01:39 PM)Dum-Dum Wrote: Have you not got a V8 in this yet?
Have you not fitted your 2.2 yet?
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
(25-10-2013, 02:10 PM)Niall Wrote: (25-10-2013, 01:39 PM)Dum-Dum Wrote: Have you not got a V8 in this yet?
Have you not fitted your charger yet?
Threads: 169
91
25-10-2013, 03:21 PM
(This post was last modified: 25-10-2013, 03:45 PM by Grant.)
(25-10-2013, 03:20 PM)rocker8742 Wrote: (25-10-2013, 02:10 PM)Niall Wrote: (25-10-2013, 01:39 PM)Dum-Dum Wrote: Have you not got a V8 in this yet?
Not sorted your matrix yet
So had a good productive day today.
Had to have the windscreen on the van replaced, so that meant waiting at home for the guy to show up. So in other words, car work!
I started the morning cheering myself up by seeing how much camber I can get out of my top mounts:
Standard
With camber:
After mucking about, I set about sorting my chronic exhaust leak(s)
First was from the fire ring, needed a new bolt as one had threaded and come loose. Easy fix.
Second was from the centre section:
So chucked a new one in there and fire gummed it all back up. Sweet as a nut!
First time I have had an exhaust that doesn't leak for about 10 months now, so loving life haha.
Then set about fitting these bad boys. 20mm hub centric spacers.
Put the front two on, but I *think* the rear arches may need rolling, so have left them for now.
Fitted the MK3 Golf arches, i think the look quite smart TBF. Needed these to get the wheels legal for the MOT with the 20mm spacers and to stop the car looking stupid.
Threads: 78
49
Looks purposeful Grant  if you do need to roll your arches you can use my roller.
Threads: 169
91
I didn't realise you had a roller. Thats a very kind offer mate, I may take you up on that in exchange for a crete of beer  Nice one!
Threads: 541
124
Looks good mate but needs lowered to make the arches and width look right IMO
Threads: 31
1
Car Model/Spec: 306 1.8
Given 2 thank(s) in 2 post(s)
V8 spec is Rover 3.5 v8 with
VIPER TYPHOON CAM, STEEL TIMING GEAR, RHOADS LIFTERS, DW060 VALVE SPRINGS, BULLETED VALVE GUIDES, PORTED & RE-PROFILED CYLINDER HEAD. (sorry for caps its copy and pasted)
Induction - MOROSO/K&N AIR FILTER, HOLLEY 390 CARB, OFFENHAUSER DUAL PLANE INLET MANIFOLD (thats the old set up cant find the injector setup)
turbo info -
Brand New T3/T4 HYBRID TURBO WITH INTERNAL WASTEGATE
Turborevs T3/T4 turbochargers consisting of a T3 turbine section,
(Stage III trim) and a T4 compressor section (T04E trim).
The T3/T4 offers the low inertia and fast boost response of the light weight T3 turbine wheel
and the high airflow characteristics of the T4 compressor family,
making the T3/T4 the turbo of choice for high performance “import” applications
Stage-3 Turbo T3/T4
Compressor Wheel / Housing A/R Ratio:
Inlet (mm): 50.5; Outlet(mm): 76; Trim (in/out x 100): 55; A/R: 0.5
Turbine Wheel / Housing A/R Ratio:
Inlet (mm): 65.5; Outlet(mm): 55.9; Trim (in/out x 100): 73; A/R: 0.63
Which is running at 15psi, producing 361bhp at the crank.
If you want any more information just ask and I'll try find it, would be awesome to see this happen!
Threads: 27
20
Take the 6 badges off you plum!!!!
Oh yeh looks good lol
Threads: 63
26
Car Model/Spec: GTi6
Threads: 117
119
Those arches look good mate, like it.
Why is everyone arguing about what engine to install and how so you can retain handling chracteristics? To make it rwd or awd you WILL completely change the handling as it requires a change away from the torsion bar type rear suspenion assembly, which is a fundamental part of what makes a 306 handle like it does. Changing which wheels are driven will also make a substantial amount of difference, as will the v8 power delivery. Imo there's no point in trying to retain handling characteristics with a project like this, just decide which engine you want and where, and how many wheels you want driven and get on with it. :p
Threads: 169
91
Haha fair point
I just don't want it handling like a sack of.
My main concern is the engine will e up front, with the rear wheels driven, so no weight over the rear wheels. Hence the rear end gearbox.
Mid-rear engined would be epic and the best solution, but I need to work out the practicalities of it. I'm just gonna have to MTFU and buy an engine to start mocking up I think
Threads: 591
54
just buy an old range rover v8.
you can pick old tatty ones up for 500quid.
get out the engine...then sell rest for parts/scrap and make the money back!
Threads: 27
20
If ιt's rwd you will have a fair amount of weight in the back anyways bud with the axel ɑnd diff
Threads: 28
1
If you're gonna go rover v8 try and get one out of a tvr  they had better compression, different cam and ported heads etc
Threads: 169
91
(26-10-2013, 10:14 AM)Jonny b Wrote: If ιt's rwd you will have a fair amount of weight in the back anyways bud with the axel ɑnd diff This is very true. I'll have to sit down with a bottle of whiskey and do the maths one night.
(26-10-2013, 12:25 PM)floz123 Wrote: If you're gonna go rover v8 try and get one out of a tvr they had better compression, different cam and ported heads etc  And a hefty price tag to go with them  Would be epic though.
Got this little beaut for a steal the other day
Threads: 591
54
http://www.ebay.co.uk/itm/1989-Range-Rov...2330d82c45
there ya go...comes with LPG kit too to make it eco!
rip out what ya need...sell what ya dont to make up the loss
Threads: 28
1
Is this the one you tried selling me Grant?
