14-10-2013, 09:49 AM
Looking good Cully.
Is this just a rebuild or have I missed something?
JP
JP
JP
Cully's spare Gti6 engine
Looking good Cully.
Is this just a rebuild or have I missed something? JP
JP
I swear everyone has an old bed sheet exactly the same as that one!
14-10-2013, 10:38 AM
(14-10-2013, 10:06 AM)Toms306 Wrote: I swear everyone has an old bed sheet exactly the same as that one! I dont ![]() Looking good cully. :-) be rude not to paint it up :-)
14-10-2013, 11:54 AM
(14-10-2013, 09:49 AM)jammapic Wrote: Looking good Cully. yes JP its a rebuild refresh i bought the engine as a scrapper, but found the problem was not what was originally diagnosed, so have decided to refresh the engine/head with new bearings and rings so it will be a good drop in and go package for my Gti6 ![]()
14-10-2013, 12:27 PM
Gotta say im glad with my engine build i had the valves and seats done at the machine shop
mmm! white paint but for how long?
16-10-2013, 03:28 PM
Well, defo the right colour for showing up your oil leaks
16-10-2013, 03:55 PM
Looking good. Wont stay that way though
16-10-2013, 04:11 PM
what alloy is the rocker cover made out of and what brand was the high temp paint?
16-10-2013, 04:16 PM
Looking good Cully!
16-10-2013, 04:56 PM
16-10-2013, 05:46 PM
Making good progress with this mate. Is this going to be a reserve engine or by the time its finished you'll just want to drop it in straight away?
been grinding in the valves today got to the last inlet valve and i find one im not happy with
it was tight to insert and was stiff sticking going to full lift so took it out to inspect it and found this dig in the side of the stem im going to replace this valve as it will only wear the guide and tear up the valve stem seal
20-10-2013, 07:12 PM
made a start stripping the block down, as im waiting on a valve, before i can reasemble the head.
im glad to say ive shed some more blood and skin. I was trying to undo the two bolts through the back of the bracket that holds the power steering pump and alternator, tight buggers but i won in the end. this engine has been apart before for sure, but to what extent im not sure yet, but the sump deffo looks like its been removed and resealed as some point on the up side ive found one 13mm 3/8 socket 2 spare inlet studs and a power steering pump bolt down the back of the alternator
20-10-2013, 07:23 PM
Going to be waiting a while for that valve. Wont be removing it till at least next weekend
20-10-2013, 07:35 PM
Billy bargain about the treasure found, not so cool about skin/blood loss
![]() ![]() the smokey old bus that sounds like a tractor...
20-10-2013, 08:00 PM
This can always be a doner engine for mine
20-10-2013, 09:58 PM
When I started stripping the XUD for the first time I found 3 8mm nuts, a torx bit and a tip from a magnetic pickup tool behind the alternator bracket! Lol
21-10-2013, 08:41 PM
some info here that might come in handy
Peugeot partnumbers and service box prices all priced each so for 16 valvestem seals multiply price by 16 XU10J4RS Head Gasket 45.84 GBP Peugeot 0209Z2 Head Bolts 7.57 GBP Peugeot 0204AO UP TO O 08581 REMOVE WASHER 0205 47 Rear Crankshaft Oil Seal 18.74 GBP Peugeot CRANKSHAFT BEARING SEAL 90X110-7SFCM - 0127 28 Front Crankshaft Oil Seal 14.34 GBP Peugeot CRANKSHAFT BEARING SEAL 42X62-7 0326 22 Camshaft Oil Seal 11.80 GBP Peugeot ENGINE CAMSHAFT SEAL DIAM 36X50-7 0236 44 Valve Stem Seals 1.39 GBP Peugeot ENGINE VALVE STEM SEAL DIAM 12 - H 10 095638 VALVE GUIDE Stem REPAR 0220 96 18.55 GBP SET OF 2 VALVE SPING 0952 A6 5.54 GBP Valve collets 0950 20 2.51 GBP Inlet valve 28.44 GBP Peugeot 094882 Exhaust valve 37.32 GBP Peugeot 0949 87 VALVE SPRING RETAINER Top 0951 36 2.40 GBP VALVE SPRING RETAINER Lower 0953 20 2.56 GBP Timing Belt Kit 98.98 GBP Peugeot DISTRIBUTION MOTOR KIT 0831 48 RP 0831 R5 Timing Belt 42.14 GBP Peugeot TIMING BELT 136 DTS HT=34 0816 98 (earlyer ph2 belt roller assembly numbers) peugeot TIMING TENSION ROLLER 0829 35 53.33 GBP Bolt GEAR-BOX HOUSING COLUMN SCREW M8X125(2) LG 16-34 0820 17 Bolt SELF LOCKING SELF-TAP SCREWS DIAM 8X125-25 6923 78 Peugeot RETRACTOR ROLLER 0830 37 RP 0830 63 27.44 GBP Bolt HEX HEAD CAPSCREW DIAM 10X150-50 6921 C2 RP 6921 91 Hydraulic Cam Follower 27.38 GBP Peugeot 0942 31 Cam cover screws SCREW WITH BASE DIAM 6X100-38 0205 51 SOCKET CHEESEHEAD SCREW DIAM 6X100-25 6913 F6 / RP 6913 N8 COOLANT MANIFOLD GASKET DIAM 42 (back of block) 1339 83 1.52 GBP WATER PUMP GASKET 1206 A4 2.58 GBP ENGINE WATER THERMOSTAT 83 DEG 1338 39 21.65 GBP ENGINE WATER THERMOSTAT GASKET DIAM 51X57-4,5 1340 48 1.10 GBP ENGINE WATER HOUSING-Block SEAL 1340 33 3.48 GBP ENGINE GASKET KIT 0197 W2 115.87 GBP GEAR-BOX SEAL 40X58-10 3121 44 RP 16 088 167 80 11.00 GBP GEAR-BOX SEAL RIGHT29X47-11 3121 46 12.94 GBP
21-10-2013, 08:52 PM
I f*cking love you cully! :-) your doing all the work for me here :-) Cheers for the part numbers going to be big help as im wanting mine to be all oe parts.
21-10-2013, 09:11 PM
21-10-2013, 09:39 PM
21-10-2013, 09:43 PM
Cheers cully! That price for the head gasket, is that a MLS gasket as im sure thats what came on these as standard? If so, thats cheap!
21-10-2013, 09:44 PM
(21-10-2013, 09:39 PM)puglove Wrote:(21-10-2013, 08:52 PM)kentiiboii Wrote: I f*cking love you cully! :-) your doing all the work for me here :-) Cheers for the part numbers going to be big help as im wanting mine to be all oe parts.
22-10-2013, 12:23 AM
(21-10-2013, 09:39 PM)puglove Wrote:(21-10-2013, 08:52 PM)kentiiboii Wrote: I f*cking love you cully! :-) your doing all the work for me here :-) Cheers for the part numbers going to be big help as im wanting mine to be all oe parts. You just feeling left out ;-)
22-10-2013, 05:20 AM
all this praise and still no rep!
as for the head gasket being MLS, i dont know, event the parts guy didnt know, he said he'd have to order to find out, and also the engine gasket kit, i dont know what that includes, it may be all of the gaskets that are needed, cause when i asked if peugeot did a head gasket kit they said no, but since i found that kit on service box
22-10-2013, 09:06 AM
22-10-2013, 09:23 AM
(22-10-2013, 05:20 AM)cully Wrote: all this praise and still no rep! Yeah I was wondering if the engine gasket kit would include the head gasket kit specially when its over £100 ill go in internet and rep ;-) (22-10-2013, 09:06 AM)puglove Wrote:(22-10-2013, 12:23 AM)kentiiboii Wrote: You just feeling left out ;-) That would be a tremendous idea jamie :-)
22-10-2013, 01:49 PM
THat is an awuful lot of parts there Paul but you can get a full set of 16 +1mm oversize valves for £335 http://www.ebay.co.uk/itm/Sinus-Performa...2a32d5cffd
22-10-2013, 04:22 PM
just to say thats not a list of what ive bought or going to buy
that is a list of partnumbers most likely to be usefull for engine builders ![]() |
Cully's Bianca 6 R150 YVM | cully | 994 | 536,005 |
13-01-2019, 04:04 PM Last Post: cully |
cully's XU10J4RS | cully | 11 | 6,166 |
30-06-2016, 12:53 PM Last Post: welshpug |
Cully's Electric car ..T project | cully | 144 | 54,661 |
16-04-2016, 04:14 PM Last Post: cully |
