1.9 dturbo stage 1 tune
Aright, well I'm not really sure. I just want a bit more power without putting the engine at huge risk. I'm not sure how far you can push the engine before you need to start spending out on an uprated clutches and intercoolers and all the other bits n bobs
#32
just set it to 18-20psi and you'll be fine
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
#33
Yeah, stick with 20psi for now, and see how you get on. Smile
#34
Yeah, im sure 20 psi will suit my needs Smile
#35
I had a great little tune on my Lucas before swapping to a Bosch. Boost compensator right down turbo 100% up and keep turning max fuel till it smokes then down a touch. About 180 degrees on mine. Went well, 20psi. T2's can handle more boost than the kkk or GT15.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
#36
I run my de-wastegated TD04L on my 205 with a Lucas pump. It's been so long I can't actually remember what it was boosting (on standard fueling)!
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
#37
Yeah, well like someone posted earlier on, every car runs a bit different, so it's just trial and error until you get the right settings
  Stage 1/stage 2 whats the difference? general tuning questions midge 5 6,346 19-07-2015, 05:55 PM
Last Post: bashbarnard
  Smokey pug & "clean tune" power? nick000 13 8,450 17-06-2014, 11:36 AM
Last Post: nick000
  lucas pump tune willJspears 10 5,659 21-11-2013, 12:41 PM
Last Post: willJspears
