Cully's spare Gti6 engine
(23-09-2013, 09:01 PM)Grant Wrote: The gaskets are normally a fiber body, with metal linings around the bores etc.
Has the head been skimmed? That will determine the thickness you will need.
Nope. On the GTi they are MLS as standard from pug (hence the £85 price Sad ) but a lot of replacements are fibrous.
#32
(23-09-2013, 09:00 PM)THE_Liam Wrote: You can see they're old gouges definitely. Can't understand the person who whipped off that head, saw those pistons and just stuck a new head on...
Marks like that aren't going to have a detrimental effect on the engine. The only thing it could have done, as Niall previously said, was knocked the big end bearings.
As long s the CR is the same you could have your face engraved in it if you wanted to lol
Wouldn't fancy those hot spots mind...
Yeah I know the dinged crowns won't make much difference, it's the underlying damage I'd be worried about. Can't imagine that sudden sharp shock was good for the rods either...
#34
All seems interesting. That engine pulled bloody well though when it was running.
I had a cambelt snap in the 205, which snapped the cam and bent 1 valve. Whacked on a new head and made 190bhp 3 days later on the dyno!
Stage 2 XUD Sedan
#35
You never know, it could have had a bottom end rebuild too, the person may have never bothered changing the pistons, as what's te point?
I guess we shall have to watch this space!
The only known issue here is as i said, with the big end shells. Replace them and your good to go Smile
#37
Which end are you numbering 1?
Flywheel end or auxiliary end?
#38
(23-09-2013, 10:28 PM)Ruan Wrote: Which end are you numbering 1?
flywheel/gearbox end
#39
heres a picture or two of the wire burs comming from the headgasket
do you think they would mess the valve seating up??
#40
Are you sure that valve/piston damage is old as the valve cut outs are full of carbon and id expect that if there was going to be valve damage pre rebuild then the valves would hit the cut outs rather than missing because (i'm assuming) someone has badly cut the valve guides so they aren't at the angle they should be.
#41
today ive cleand the workbench and the garage up a bit so ive got the head on the bench have taken out number 1 exhust valves and i have found carbon foulings on the seats the valves themselves look good!
i think this engine needs a damn good de carbon and a refresh
and it will be a good one Smile
Valve seats need lapping in but look good other than the carbon
Valves themselves look good other than the build up of carbon
what i need to know now is how do i know if the head has any meat left for skimming
how do you measure the original head hight or whats left of the head ????
#42
There should be notches on the head that a machine shop will be able to tell if ιts got meat left on or ιs scrap bud
[Image: SDC10442-1.jpg]
#43
Very interesting read this, got the head off mine today, well sort of need to get exhaust manifold off tho was hoping i could get the head out with it on and it turns out you carnt lol
Are the pistons supposed to be dead flat then? or have them cut outs on? or is it that they valves probably hit them in the past?
#44
yes these pistons are flat with valve cutouts but if you look carefull you can also see previous valve contact
been a bit busy today on other things but i will get some more pictures of the casting marks ref head skimming depths
#45
meanwhile in the kitchen!
#46
thats sooo win!!!! going to but my wheels in the sink and wash them see how well that goes down with the mrs lol
#47
(05-10-2013, 05:37 PM)puglove Wrote: see how well that goes down with the mrs lol
I thought that about cullys head lol
[Image: siggy1.jpg]
#48
maybe i should of waited till she went out Sad
next time il use the dishwasher Smile
hmm think im sleeping i the dog house tonight
#49
(05-10-2013, 05:49 PM)cully Wrote: hmm think im sleeping i the dog house tonight
But well worth it for the lolz
#50
Your dog house is nearly the size of my actual house and has electric, cant complain really.
#51
i do that quite often, and generally use up all the scouring pads and sponges getting to all the oily crap..lol
engine degreaser and an old dishwasher is an interesting idea though.. Smile
Project: Formula Peugeot
#52
This thread will come in incredibly handy when I get round to replacing/rebuilding my engine! Keep this up with all the photos, this will be invaluable to me mate!
#53
the sink trip didnt get all the crap off before i was thrown out!
so tomorrow im setting up the pressure washer in the new shower cubical while shes at work Big Grin
jokin!!
but will hit it with the pressure washer in the garden Wink
#54
(05-10-2013, 07:47 PM)cully Wrote: the sink trip didnt get all the crap off before i was thrown out!
jokin!!
Try autoglym engine cleaner. Worked well under my bonnet with minimal scrubbing.
#55
Yeah autoglym engine and machine cleaner is a favourite of mine, will even shift the EGR crap out a HDi manifold with minimal scrubbing
#56
If you really don't like your dish washer soak the parts in engine degreaser then set the dish washer going on a hot wash, use rise aid too keeps everything shiney
#57
tip i forgot to add when taking the valves out the head!
make yourself a board to hold the springs washers and valves it will help keep things organised for when you reasemble or grind the valves
so back to the head cleaning Big Grin
TRF solution and a pressure washer
jobs a good one dryed off with an airline then sprayed the valve seats with WD40 to stop them rusting before i send to the machine shop for checking
#58
THem seats have definitely been cut in before!
Loving the progress with this. Im getting itchy fingers already with out a car to mess with. might have to get something lol
#59
This is a really interesting read! I'm looking forward to the rest of your progress.
It's the sort of thing that could be used as a partial guide for head dismantling on the 6, and also for signs of wear and what to look for in terms of damage Smile
#60
Whats not right:
  Cully's Bianca 6 R150 YVM cully 994 844,872 13-01-2019, 04:04 PM
Last Post: cully
  cully's XU10J4RS cully 11 10,103 30-06-2016, 12:53 PM
Last Post: welshpug
  Cully's Electric car ..T project cully 144 96,531 16-04-2016, 04:14 PM
Last Post: cully
