viva la red turd
viva la red turd
Coming along nicely ThumbsUp
(25-08-2013, 08:02 AM)Dum-Dum Wrote: 12psi is probably a slight leak but she's looking good
I'll have my stage 2 tune next week and that should be 14-15psi ill see how that pans out and check for boost leaks. But isnt there a preasure drop ? As im still on the stock map
Thanks dude
There'll be a pressure drop of a couple of psi across the system, that's about right if you're taking your boost reading from the inlet elbow like most do. Worth checking the system for leaks anyway imo if you've got the time, some weak washing up liquid mix sprayed around joints should do it.
  The Hdi turd budget/fun car Torsten_23 17 7,055 10-08-2014, 01:18 PM
Last Post: Tom
