Threads: 448
51
I want a straight through on the dt, and I'm getting impatient.
Having a decat - mid box - mid box is straight through right?
Or did I miss something with these backboxmidbox swap around?
Or what's the cheapest way to straight through? Over the counter parts? Welder? Silicon pipes and exhaust?
Also what's the standard width of a dt exhaust?
Threads: 63
26
Car Model/Spec: GTi6
Silicone pipes? For an exhaust?
Threads: 33
Car Model/Spec: 306 D-turbo/306 Rallye
Have a look in my project thread, i had a full straight through exhaust made from the turbo back at AA silencers in Stafford, if your anywhere near there? was only 86 pounds anyway
Blaze '6 and Blaze D-turbo!
Threads: 448
51
Nah I'm on the Isle of Wight, welders and resources are low. It's a shit tonne harder to get anything done here!
Threads: 130
82
Car Model/Spec: 106 GO-NAD
yep silicone was my idea, mainly cuz that's all i had lying around and couldnt be arsed doing it properly, it was at the back, and its rated to 200 degrees anyway, it worked.
also matt, f*cking fail, exhaust in the interior section? noob
Threads: 448
51
It's in interior/exterior and ice, last time I checked, exhaust was exterior.
It's just the backbox really, xantia had a straight through mid? Does it Fit the same as a 306 mid? More or less the same design?
Threads: 70
7
Car Model/Spec: Astor GTI6
405 has a straight through mid AFAIK too.
Threads: 541
124
Its pretty much the same but different. However you could use it to make a straight through back box.
