Oil breather hose
Oil breather hose
Has anyone got a part number for his it's the rubber one on top of then engine thanks.
Oil Filler to Rocker Cover Breather Hose? Peugeot: 1180 86
Only know this because I bought one recently
Yes that's it cheers dude
how much are they? mine's been split for ages . .Smile
IIRC it was £7.20 ish
Does anyone have the dimensions of this hose please ?. It's a weird one because it goes from a large end then shrink's down into a small pipe.
Well worth buying new I broke a few down the scrappy before I found a decent one. Didn't realise they were that cheap
HDi Cabby Project Click
Yeah, always go brittle as f*ck and break, worth replacing!!
suffers the same as injector leak off pipes.
I bought mine £7 something from peugeot
BUMP - thanks, needed the part number!
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
(05-07-2013, 03:24 PM)Mattcheese31 Wrote: how much are they? mine's been split for ages . .Smile
Mines been completely missing for even longer.
Just got two £6.something each.
S14 Zenki Build
don't you lose quite a bit of oil out of it mate? . . . . if we're on about the same bit you will do . .Smile
(08-03-2014, 09:51 AM)Mattcheese31 Wrote: don't you lose quite a bit of oil out of it mate? . . . . if we're on about the same bit you will do . .Smile
Me and Zak tried leaving mine without one, it absolutely pisses out!!
S14 Zenki Build
exactamundo . . . .Smile
The pipe connecting the plastic oil dipstick bit to the TMIC??
No mine occasionally lets out some oil vapour, which causes the odd buttock clenching moment as it looks just like smoke coming from under the bonnet.
but no it doesn't spray out of mine.
(my stat has been removed btw, the engine runs between 70 and 80 deg, I can't be assed to fix it)
(07-03-2014, 04:52 PM)r3k1355 Wrote: Mines been completely missing for even longer.
no not the tmic mate it connects to the engine/rocker cover . . .Smile
Bump, anyone got any tips on how to access it for replacement without ripping half the engine apart?
S14 Zenki Build
It's right at the top of the engine? Just pull the TMIC off.
No curt.. Just no.. Tongue
Tmic is off. The bastards behind the fuel filter housing!
S14 Zenki Build
You're not trying hard enough then, it's a piece of piss. It's not behind the fuel filter housing, it connects to the dipstick/filler housing.
Guess I'll find out when I get to the car. Happy days if it's a piece of piss.
S14 Zenki Build
I find it easier to remove the end glowplug line, can be fiddly to get it onto the back of the oil filler housing
  oil out of breather under hard cornering zx_volcane 9 6,798 19-07-2017, 11:45 AM
Last Post: zx_volcane
  Gearbox Breather maxaret 21 10,052 27-03-2016, 10:20 PM
Last Post: bigcheez2k3
  Breather hose billythekid 5 3,354 18-03-2014, 12:18 PM
Last Post: padge
