21-06-2013, 12:16 AM
nice little guide on the beam mounts, got the same job coming up myself very soon
| The following warnings occurred: | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Cully's Bianca 6 R150 YVM
21-06-2013, 01:58 PM
Good work mate
26-06-2013, 05:14 PM
hmmmm Bollocks!
have been to have the car all tracked up have all the measurements fronts been adjusted, rear left is spot on! rear right looks as if it may have a bent stub axel so looks like im going to get heavy with a large hammer and knock the shaft out once i find a replacement
26-06-2013, 05:25 PM
Is that your new/rebuilt axle thats bent?
looks that way
but remember the axles and arms are my originals the beam was rebuilt with new inner Axel pins and bearings not the outer wheel axles it was probably bent when i bought the car as that side is the side the beam colapsed
26-06-2013, 05:51 PM
Surely they should of checked it thoroughly before rebuilding it though?
26-06-2013, 06:06 PM
probably not noticable untill the tracking gauges were used
i didnt notice it
28-06-2013, 04:20 PM
so the puddle sucker has gone
im now back to a std airbox and snorkel with a nice bit of blue silicon and an ash filter for the ICV
28-06-2013, 04:23 PM
good move paul
did you manage to get a K&N for the box?
28-06-2013, 04:28 PM
no didnt get a K&N just a std filter for now
01-07-2013, 10:16 AM
have been out and fitted new exhust rubbers as the old ones were shot,
have stopped the rattle from the rear heat sheild, snapped bolts! so ground the studs off and drilled and fitted a threaded insert to the underfloor so now i have a firm screw point and no rattle once bolted up and ive had another look at what i thought was a bent stub axel well i dont think it is now as the Camber on the printout is correct its only the Toe thats out when i look at the readings on the printout i realised the N/s is toe in and the O/s is toe out so out with the tape measure and the beam is not square! probably after ive done the beam mounts D O H!!!!!! O/S is about 5mm further back than the N/s so tomorrow mornings job is to square up the beam
01-07-2013, 12:42 PM
Is there an easy way to square up the beam? Because i'm not sure mine is exactly straight, at least the gauges reckon it isnt lol.
01-07-2013, 02:12 PM
Thats a real smart thought, far easier than replacing it and still being wrong lol.
01-07-2013, 03:25 PM
(01-07-2013, 12:42 PM)Poodle Wrote: Is there an easy way to square up the beam? Because i'm not sure mine is exactly straight, at least the gauges reckon it isnt lol. well to check ive measured from a fixed point on the body to a fixed point on the wheel/hub to realine i will loosen the underside lower rear mount, and the and the top of this mount as it was slotted, and slacken the two top front mounts both sides, then hope to be able to bump move the beam with the wheels in the air, to its square position we will see the outcome tomorrow
05-07-2013, 11:11 AM
FIRE TIME!!
started cleaning up my old mounts so i can convert them to solids
05-07-2013, 11:36 AM
OOH interestinggggggg
05-07-2013, 06:14 PM
yes very nice but at £130 you can keep them
in build mine for less than £30
05-07-2013, 06:19 PM
(05-07-2013, 06:14 PM)cully Wrote: yes very nice but at £130 you can keep them Fancy doing me? some please i have so much to do on the six i got a little excited on Monday and totally stripped the rear end of the car to refurb and you love pissing about cully you know you do
05-07-2013, 06:24 PM
sorry puggie this is my experiment but instruction will be here for yourself to follow
![]() yes your right though i do like playing with my garage toys
05-07-2013, 06:42 PM
(05-07-2013, 06:24 PM)cully Wrote: sorry puggie this is my experiment but instruction will be here for yourself to follow Sweet i will keep an eye on your updates. did you get the front snorkle? in the end for the air box got one here if needed dude cover the postage
Thing is though if you don't get these exactly right its going to throw the track of the car out, and this would have quite a serious effect on the handling and not in a good way lol, so £130 isn't that bad lol, did you make a jig from your new set before you fitted them?
05-07-2013, 07:32 PM
im in the process of making the rear pair.they will be the easy ones
i will make a jig for the front pair as they are a little harder to get right
05-07-2013, 09:26 PM
anyone got any glue!
05-07-2013, 10:41 PM
Interesting
05-07-2013, 11:25 PM
Nice work going on here cully! Keen to see these mounts when you have done them!
They should look like this when done right. Not too pikey I reckon.
http://www.306gti6.com/forum/showthread....059&page=1 ![]() ![]() ![]() Supplied in any colour you like as long as it's Cherry red. ![]() ![]() ![]() [/quote]![]() Got lots of pre cut plates as supplied to Mr Cully if people are interested in making their own. Word of warning however, these are safety critical components and this job should only be attempted by a competent welder/fabricator with suitable equipment. Safety blurb out of the way, carry on enjoying the project.
06-07-2013, 08:39 AM
oh yes ^^^^^
i might of cheated a little bit with the plates ![]() thanks goes too Daveyboy for supplying me the plate sets ask him nicely and im sure he will do the same or even supply the completed mounts ive got to make a nice job on the welding so it looks easy to do
06-07-2013, 10:53 AM
whats a plate set cost then paul?
06-07-2013, 11:37 AM
£27.50 posted
| cully's XU10J4RS | cully | 11 | 9,781 |
30-06-2016, 12:53 PM Last Post: welshpug |
| Cully's Electric car ..T project | cully | 144 | 93,874 |
16-04-2016, 04:14 PM Last Post: cully |
