26-05-2013, 10:33 PM
Roughly how many degrees should I be able to twist the aux belt at its longest run? Mine will go to 90 degrees quite easily but I'm not sure if its tight enough..
aux belt tension
26-05-2013, 10:46 PM
Has the belt been tensioned up properly?
For an HDi: Pull back and lock off the top auto tensioner, loosen the lower elliptical tensioner, adjust so it takes up the slack and retighten, then release the top tensioner - it will set the correct tension itself.
26-05-2013, 10:55 PM
Ok I think I've down it backwards then, will sort it tomorrow.
| Oil pump chain tension | DeeTurbo | 3 | 3,274 |
13-06-2017, 08:10 AM Last Post: DeeTurbo |
| help - aux belt tension | rd070707 | 47 | 23,890 |
12-12-2012, 09:00 PM Last Post: rd070707 |
