Oil pump chain tension
Hi,
I've noticed there is more slack then I thought there would be on the chain to the oil pump.
Is there a auto tensioner on these engines or is the slack normal?
Fairly normal for there to be some slack, although i expect 340k of wear has got something to do with it. So long as you can't make it slip a tooth it'll be fine.
check the tooth wear, theres no tensioner but there is a shim under the pump. only one size though.
Nice one, thanks guys.
I did check the sprocket for wear and it looks good.
Chain is a little loose on it but no where near slipping off or teeth.
I should have videoed the movement of the chain for your opinion but it sounds fine.
Sent from my ONEPLUS A3003 using Tapatalk
  aux belt tension Ricky 2 2,776 26-05-2013, 10:55 PM
Last Post: Ricky
  help - aux belt tension rd070707 47 24,496 12-12-2012, 09:00 PM
Last Post: rd070707
